Home » Archived » Test and Performance Tools Platform (TPTP) » Integrated Agent Controller
Integrated Agent Controller [message #51095] Fri, 20 January 2006 05:55 Go to next message
Originally posted by: tomas.walch.NOSPAMproventek.com
Hi.
I'm now trying to launch a manual test on a Linux platform, but with no
sucsess:
The integrated agent controller won't work it seems like, still if I go to
Settings->Profiling and Logging->Hosts, select the "Local
Direct Connection" and test the connection I get the following
message:"The Remote Agent Controller(RAC) is currently running.
You need to stop the Remote Agent Controller before activating the Local
Connection. To stop the Remote Agent Controller use the system Service
utility."
The RAC is NOT running!
My system is:
Eclipse 3.1
Sun Java 1.4.2_10
TPTP 4.1
Ubuntu Linux 5.10 w/ kernel 2.6.12
/Tomas W.
Re: Integrated Agent Controller [message #51123 is a reply to message #51095] Fri, 20 January 2006 09:25 Go to previous messageGo to next message
sorry, found that a bug has already been posted on this.
Re: Integrated Agent Controller [message #51289 is a reply to message #51123] Mon, 23 January 2006 11:59 Go to previous messageGo to next message
Would you mind posting the bug number you are referring to? There might be a
workaround available. Thanks.
Samson
"Tomas Walch" <tomas.walch@NOSPAMproventek.com> wrote in message
news:ded4b57dd8f309bdee7c4079c971c102$1@www.eclipse.org...
Re: Integrated Agent Controller [message #51370 is a reply to message #51289] Tue, 24 January 2006 04:02 Go to previous message
try that:
If a RAserve is running, stop it.
and remove the file /tmp/IBMRAC/ramaster
Previous Topic:Automated GUI Recorder capabilities
Next Topic:How to Use TPTP
Current Time: Fri Oct 31 17:05:04 EDT 2025
Powered by FUDForum. Page generated in 0.12493 seconds
