Home » Language IDEs » C / C++ IDE (CDT) » Dynamic universal Make file
Dynamic universal Make file [message #51060] Wed, 20 November 2002 08:51 Go to next message
I want to create an "universal" dynamic Make file that we can use for all
our c projects. The projects will consist out of multiple c modules which
all will "create" a corresponding .exe file.
I managed to create a Make where all c modules and their resultant .o &
exe files end up in the same directory.
= Start Make 1
# Dynamic Make file
# for each .c module in the project (= CurDIR)
# a corresponding .o & .exe wil be created
RootPath = c:\data\ExtFiles\
CC = GCC
SRC := $(wildcard *.c)
OBJ := $(SRC:.c=.o)
EXE := $(SRC:.c=.exe)
INC = $(RootPath)\inc
LIB = $(RootPath)\lib\xxxxxxxx.lib
Phony: all clean
all: $(EXE)
(EXE): %.exe : %.o
$(CC) -o $(@) $(<) -I$(INC) $(LIB)
$(OBJ): %.o : %.c
$(CC) -c $(<) -I$(INC)
= End Make 1
However for various reason's we would like to create the following
directory structure "under" our project.
Project
+- src <- C source modules
+- inc <- includes (.h) files
+- obj <- result of compiles
+- exe <- result of links
For each Project\src\*.c a corresponding .o file is created in
Project\obj\*.o
For each Project\obj\*.o a corresponding .exe file is created in
Project\exe\*.exe
Directory Project is a subdirectory under Eclipse\Workspace\
Here is my attemp. After struggeling for 2 days, yep I'm a Make beginner,
I even wonder if it can be done. I even started looking at Make
replacements !!!
I use GnuMake and run Eclipse on a Win machine by the way.
Thanks for the help.
= Start Make 2
CC = GCC
SRCDIR = $(CURDIR)/src
OBJDIR = $(CURDIR)/obj
EXEDIR = $(CURDIR)/exe
SRC := $(wildcard $(SRCDIR)/*.c)
OBJ := $(SRC:.c=.o)
OBJ := $(subst src,obj,$(OBJ))
EXE := $(subst src,exe,$(EXE))
all: $(EXE)
$(EXE): $(OBJ) <--+ the problem is here.
Whatever
$(CC) -o $(@) $^ $(LIB) | I do I just can't get the
$(OBJ): $(SRC) <--+
$(CC) -c $? -I$(INC) -o $(@)
= End Make 2 ==================================
Re: Dynamic universal Make file [message #51147 is a reply to message #51060] Wed, 20 November 2002 09:02 Go to previous messageGo to next message
what I was trying to say here :
> Whatever
> $(CC) -o $(@) $^ $(LIB) | I do I just can\\\'t get the
> $(OBJ): $(SRC) <--+
Is that whatever I do I cant seem to get the target to point to the
corresponding changed .o and/or .c. It keeps on seeing the while string of
all .o or .c files as dependeances. How do I point get make so far to
point only to the ONE corresponding .o or .c files.
Re: Dynamic universal Make file [message #51579 is a reply to message #51060] Fri, 22 November 2002 13:44 Go to previous messageGo to next message
Originally posted by: Stephen.Kennedy.havok.com
Try:
obj/%.o : src/%.c
And similarly exe/% : obj/%.o
Stephen.
Re: Dynamic universal Make file [message #51800 is a reply to message #51579] Mon, 25 November 2002 03:05 Go to previous messageGo to next message
Stephen Kennedy wrote:
> DQpUcnk6DQpvYmovJS5vIDogc3JjLyUuYw0KICAgICQoQ0MpIC1vICQoQCkg JCg8KSAtSSQoSU5D
> KSAkKExJQikgDQoNCkFuZCBzaW1pbGFybHkgZXhlLyUgOiBvYmovJS5vDQoN ClN0ZXBoZW4uDQo=
Re: Dynamic universal Make file [message #51881 is a reply to message #51579] Mon, 25 November 2002 09:40 Go to previous messageGo to next message
(outlook munged that, lets try again)
Try:
obj/%.o : src/%.c
Stephen.
Re: Dynamic universal Make file [message #52165 is a reply to message #51881] Tue, 26 November 2002 05:56 Go to previous messageGo to next message
Thanks Stephen :)
You suggested change did not work but you have pointed me in another
direction with the \"appending\" of the directory. I did not one could to
that. I have somthing else to \"work\" with now :)
Regards Johannes.
ps. the error I get is \"No rule to make target \'exe/%, need by \'all\'.
Stop\"
I can\'t seem to get all to \"point\" to exe/% : obj/*.o
Re: Dynamic universal Make file [message #52930 is a reply to message #51060] Sun, 01 December 2002 22:53 Go to previous messageGo to next message
Have you though about just using autoconf, automake and libtool? You might
save yourself quite a headache...
Just a thought.
Andrew
> = Start Make 1
> # Dynamic Make file
> CC = GCC
> OBJ := $(SRC:.c=.o)
> Phony: all clean
> all: $(EXE)
> (EXE): %.exe : %.o
> $(OBJ): %.o : %.c
> = End Make 1
> Project
> Project\obj\*.o
> Project\exe\*.exe
> replacements !!!
> = Start Make 2
> CC = GCC
> OBJ := $(SRC:.c=.o)
> all: $(EXE)
> Whatever
> $(OBJ): $(SRC) <--+
Adding and Removing Widgets [message #62178 is a reply to message #52930] Fri, 14 February 2003 09:38 Go to previous message
Originally posted by: bijukp2000.rediffmail.com
Hi All.
Did SWT api support adding and removing widgets dynamically to
org.eclipse.swt.widgets.Composite
on user interactions ?.
I didn't find any api methods to add and remove widgets.
Please advise me how to proceed.
Biju
Previous Topic:Outline problem with anonymous structs
Next Topic:JNI Problems
Current Time: Tue Jul 15 21:53:44 EDT 2025
Powered by FUDForum. Page generated in 0.29081 seconds
