Home » Eclipse Projects » Plugin Development Environment (PDE) » [Jade] Can't get a proxy to the Platform Manager
[Jade] Can't get a proxy to the Platform Manager [message #51059] Thu, 19 March 2009 09:32 Go to next message
Hi, I have a "big" problem, and here it is...
I'm developing a Plugin Project for Eclipse 3.3 and I want to use Jade
(3.6.1 http://jade.tilab.com) with this project. So, I need to start my
Jade agent platform just clicking a button or a menu entry in this
interface, it seems everything so simple but... it doesn't works.
The weirdest thing is that the same code, when executed in a separate "non
pde" project, works fine!
Explanation:
1) If I try to run jade platform from within my eclipse plugin project,
the boot fails.
2) If I create a separate "normal java" project and execute the SAME
snippet of code it boots successfully! I've tried to create a jar library
file with this "working project" and use it inside the plugin one, but
this fails again.
Here it is the stack trace printed when the execution stops:
Mar 19, 2009 10:24:24 AM jade.core.AgentContainerImpl joinPlatform
SEVERE: Some problem occurred while joining agent platform.
jade.core.ProfileException: Can't get a proxy to the Platform Manager
[nested jade.core.IMTPException: Communication failure while starting JADE
Runtime System. Check if the RMIRegistry CLASSPATH includes the RMI Stub
classes of JADE. [nested java.rmi.ServerException: RemoteException
occurred in server thread; nested exception is:
java.rmi.UnmarshalException: error unmarshalling arguments; nested
exception is:
java.lang.ClassNotFoundException: jade.imtp.rmi.ServiceManagerRMI (no
security manager: RMI class loader disabled)]]
at jade.core.ProfileImpl.createPlatformManager(ProfileImpl.java :568)
at jade.core.ProfileImpl.getPlatformManager(ProfileImpl.java:48 1)
at jade.core.ProfileImpl.getServiceManager(ProfileImpl.java:495 )
at jade.core.AgentContainerImpl.init(AgentContainerImpl.java:32 8)
at jade.core.AgentContainerImpl.joinPlatform(AgentContainerImpl .java:464)
at jade.core.Runtime.createMainContainer(Runtime.java:148)
at jade.Boot.<init>(Boot.java:134)
at jade.Boot.main(Boot.java:68)
it.gruppors.phoenix_epp.controller.agent.platform.PlatformLa uncher.bootJade(PlatformLauncher.java:55)
it.gruppors.phoenix_epp.controller.actions.LaunchAgentPlatfo rmAction.run(LaunchAgentPlatformAction.java:42)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at it.gruppors.phoenix_epp.Application.start(Application.java:2 2)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Nested Exception:
jade.core.IMTPException: Communication failure while starting JADE Runtime
System. Check if the RMIRegistry CLASSPATH includes the RMI Stub classes
of JADE. [nested java.rmi.ServerException: RemoteException occurred in
exception is:
jade.imtp.rmi.RMIIMTPManager.exportPlatformManager(RMIIMTPMa nager.java:286)
at jade.core.ProfileImpl.createPlatformManager(ProfileImpl.java :557)
Nested Exception:
java.rmi.ServerException: RemoteException occurred in server thread;
exception is:
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef .java:396)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.ja va:250)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:535)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TC PTransport.java:790)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:649)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServ er(StreamRemoteCall.java:255)
sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteC all.java:233)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:359)
at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
at java.rmi.Naming.bind(Naming.java:111)
jade.imtp.rmi.RMIIMTPManager.exportPlatformManager(RMIIMTPMa nager.java:237)
Caused by: java.rmi.UnmarshalException: error unmarshalling arguments;
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef .java:386)
Caused by: java.lang.ClassNotFoundException:
jade.imtp.rmi.ServiceManagerRMI (no security manager: RMI class loader
disabled)
at sun.rmi.server.LoaderHandler.loadProxyClass(LoaderHandler.ja va:535)
at java.rmi.server.RMIClassLoader$2.loadProxyClass(RMIClassLoad er.java:628)
at java.rmi.server.RMIClassLoader.loadProxyClass(RMIClassLoader .java:294)
sun.rmi.server.MarshalInputStream.resolveProxyClass(MarshalI nputStream.java:238)
at java.io.ObjectInputStream.readProxyDesc(ObjectInputStream.ja va:1531)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1493)
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1732)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1329)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 351)
Re: [Jade] Can't get a proxy to the Platform Manager [message #51281 is a reply to message #51059] Thu, 19 March 2009 14:42 Go to previous message
May be Jade forum would be a better place to raise this query
http://jade.tilab.com/community-index.htm
However, my 2 cents:
Since you are able to run it as Java project, you should be able to run
it as Plugin as well.
1. Right click on your java project and choose "Configure -> Convert to
Plugin projects...".
If it still doesn't work
2. Add the jade jars to your plugin using manifest editor -> build ->
runtine information -> add library.
hth,
Ankur..
Re: [Jade] Can't get a proxy to the Platform Manager [message #593646 is a reply to message #51059] Thu, 19 March 2009 14:42 Go to previous message
hth,
Ankur..
Previous Topic:Query target platform for a plugin id
Next Topic:Workbench view is not retaining the state in the new plugin.
Current Time: Mon Sep 01 00:55:39 EDT 2025
Powered by FUDForum. Page generated in 0.05353 seconds
