Home » Archived » Test and Performance Tools Platform (TPTP) » Error executing recorded test suite.
Error executing recorded test suite. [message #51008] Thu, 19 January 2006 18:11 Go to next message
Originally posted by: talktomanalar.yahoo.com
Apologies if this is not the correct newsgroup to post a testing problem.
I created a test suite by using the HTTP Recorder. I was able to
generate the source, but am unable to execute (right click -> Run As ->
Test) the test. The following error appears in the log file.
!ENTRY org.eclipse.hyades.test.core 1 0 2006-01-19 14:14:45.34
!MESSAGE
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
!STACK 0
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:417)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2058)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1856)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:692)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Any ideas? My environment is Eclipse 3.1.1, TPTP Test 4.1.0 and XSD 2.1.0
regards
m~
Re: Error executing recorded test suite. [message #51397 is a reply to message #51008] Tue, 24 January 2006 16:25 Go to previous messageGo to next message
This error is a common catch-all exception within the Test Execution
Harness indicating that the test could not be executed. We will have to
dig deeper to find the true problem.
Which JRE are you using? I have tested with IBM 1.4.2 but not with 1.5 .
Make sure you are using a supported JRE. Also, make sure the RAC is
running. Look at the servicelog.log file in %RASERVER_HOME%\config
directory and see if it gives a more detailed error message.
Additionally, look at the error log by Windows->Show View->Error Log.
Let me know if any of these suggestions help. If not, we will keep trying.
Re: Error executing recorded test suite. [message #52224 is a reply to message #51397] Tue, 31 January 2006 11:21 Go to previous message
Thank you Mark. I was able to get it to work by reinstalling all the
components. Seems like I was using an incorrect version of RAC earlier.
BTW I am using Java version 1.4.2_05.
> . Make sure you are using a supported JRE. Also, make sure the RAC is
Previous Topic:runtime.CoreException
Next Topic:unable to create the selected preference page - org.eclipse.hyades.trace.ui
Current Time: Tue Jun 03 21:44:47 EDT 2025
Powered by FUDForum. Page generated in 0.03608 seconds
