Home » Eclipse Projects » Mylyn » Integration with the History view
Integration with the History view [message #51007] Fri, 27 June 2008 08:08 Go to next message
I am starting to use Mylyn (at least trying to ;-). I am quite impressed
by the quality of the tools you guys a re providing. Congrats!
In EMF we use the following pattern when entering the comment for our
CVS commits (ignore the single quotes): '[bugzilla number] comments'
(ie, the bugzilla number in square brackets, followed by a space, and
then a text usually describing the changes on the files). So I've set
'Task>Team>Comment Template' to '[${task.key}] ${task.description}'.
My question, as hinted on the subject, is regarding "Mylin's integration
with the History view. In my workspace, the bugzilla # in this view is
not a link and I get a 'Unable to match task. Open Repository Task
dialog?' when I right click a version and hit 'Open Corresponding Task'.
Is this the expected behavior or should I be seeing a nicer integration
here ;-) ? Btw, I did set the project's task repository to Eclipse.org.
I am using Eclipse 3.4 with Mylyn 3.0 (3.0.0.v20080619-1900).
Thanks in advance,
Marcelo
Re: Integration with the History view [message #51197 is a reply to message #51007] Fri, 27 June 2008 16:50 Go to previous messageGo to next message
Hi Marcelo,
Thanks. Great to hear that you are trying it out :).
The Bugzilla hyperlink detector expects a prefix ("task" or "bug") to
recognize task ids. You could file a new feature request if using "#" as a
prefix is a common convention in EMF.
I am not sure why 'Open Corresponding Task' is failing though, it should
work based on the specified commit comment template. Please file a new bug
report and we can investigate further:
http://www.eclipse.org/mylyn/bugs/
Steffen
Re: Integration with the History view [message #51412 is a reply to message #51197] Mon, 30 June 2008 03:18 Go to previous messageGo to next message
Maybe Marcelo could be interested in my enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198361
Mauro.
Re: Integration with the History view [message #51743 is a reply to message #51197] Wed, 02 July 2008 18:55 Go to previous messageGo to next message
<html>
<head>
<title></title>
</head>
Thank you for the quick answer!&nbsp; I've opened the feature request
(239376) as you've suggested.<br>
<br>
Cheers,<br>
Marcelo<br>
<br>
Steffen Pingel wrote:
<blockquote cite="mid:g43jr8$elc$6@build.eclipse.org" type="cite">
<pre wrap="">Hi Marcelo,
</pre>
<blockquote type="cite">
<pre wrap="">I am starting to use Mylyn (at least trying to ;-). I am quite impressed
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">In EMF we use the following pattern when entering the comment for our
'Task&gt;Team&gt;Comment Template' to '[${task.key}] ${task.description}'.
</pre>
</blockquote>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/mylyn/bugs/">http://www.eclipse.org/mylyn/bugs/</a>
Steffen
</pre>
</blockquote>
</body>
</html>
Re: Integration with the History view [message #51766 is a reply to message #51412] Wed, 02 July 2008 18:58 Go to previous message
Hmmm ... Although I don't know much about the implementation details,
from your description it does seem that this enhancement would solve the
issue I am seeing when I use the 'Open Corresponding Task' action.
I've added my self to the cc list of the bugzilla.
Marcelo
>> new bug
> Cheers,
> Mauro.
Re: Integration with the History view [message #590553 is a reply to message #51007] Fri, 27 June 2008 16:50 Go to previous message
Hi Marcelo,
Steffen
Re: Integration with the History view [message #590662 is a reply to message #51197] Mon, 30 June 2008 03:18 Go to previous message
Mauro.
Re: Integration with the History view [message #590723 is a reply to message #51197] Wed, 02 July 2008 18:55 Go to previous message
<html>
<head>
<title></title>
</head>
<br>
Cheers,<br>
Marcelo<br>
<br>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
Steffen
</pre>
</blockquote>
</body>
</html>
Re: Integration with the History view [message #590733 is a reply to message #51412] Wed, 02 July 2008 18:58 Go to previous message
Marcelo
>> new bug
> Cheers,
> Mauro.
Previous Topic:Mylyn as a todo-list and more
Next Topic:Getting message: "Offline storage stop failed"
Current Time: Fri Nov 07 22:17:33 EST 2025
Powered by FUDForum. Page generated in 0.03965 seconds
