Home » Eclipse Projects » GEF » The Command in GEF & EMF
The Command in GEF & EMF [message #50985] Tue, 24 December 2002 11:43 Go to next message
Originally posted by: eric_to_jeff.hotmail.com
I write a program use EMF as model framework & GEF as presentation,
Now the problem is both gef & emf have its undo mechanism, and they have
the same api but does not implements the same interface. How about merge
them? Just like WSAD do!
Eric Suen
Re: The Command in GEF & EMF [message #51039 is a reply to message #50985] Tue, 24 December 2002 16:01 Go to previous messageGo to next message
Eric,
GEF is using its own copy of the EMF common command package. It should be
using the official library.
Frank.
Eric Suen wrote:
> Regards
> Eric Suen
Re: The Command in GEF & EMF [message #51178 is a reply to message #50985] Thu, 26 December 2002 12:05 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
EMF does not require you to use their Command implementation unless you are
using EMF Edit. I would recommend avoiding EMF Edit.
"Eric Suen" <eric_to_jeff@hotmail.com> wrote in message
news:aua23r$gkf$1@rogue.oti.com...
> Regards
> Eric Suen
Re: The Command in GEF & EMF [message #51284 is a reply to message #51178] Fri, 27 December 2002 04:03 Go to previous messageGo to next message
Can you give me some reason?
Eric Suen
Re: The Command in GEF & EMF [message #51310 is a reply to message #51178] Fri, 27 December 2002 11:04 Go to previous messageGo to next message
Randy,
I know of several people that are going to hit this problem soon. It makes
perfect sense to add a GEF view to an EMF editor. Omondo is already doing this
with EclipseUML; they're using EMF.Edit for the outline view, GEF for the
graphical UML view. If they want to make undo/redo work properly, and I'm sure
they will eventually, they'll need GEF and EMF.Edit to share the same command
stack.
How about GEF provide an alternate packaging for EMF users, gef_for_emf.zip, or
something like that, that doesn't include it's own copy of the common command
interfaces, but instead "requires" the EMF ones to be there.
Frank.
> > Hi,
> > Regards
> > Eric Suen
Re: The Command in GEF & EMF [message #51365 is a reply to message #51284] Fri, 27 December 2002 17:18 Go to previous messageGo to next message
news:auh48a$pkm$1@rogue.oti.com...
I would try writing your own content provider and label provider
implementations first. I've done this for a very complex EMF application
before, and it is pretty straightforward. EMF Edit generates complicated
code that just gets in the way of doing anything different from the
defaults, such as displaying "grouping" treeitems that have no corresponding
model object. EMF Edit also complicates things when you try to have some
control over the contents of the property sheet. I found it was much easier
just to write an IPropertySource adapter myself for the property sheet.
> Eric Suen
Re: The Command in GEF & EMF [message #51701 is a reply to message #51365] Mon, 30 December 2002 13:24 Go to previous messageGo to next message
Randy,
Non-modeled "grouping" tree items are one of the most common customizations;
it's not very hard to do at all. I don't know what kind of property sheet
control you were looking for, but I've managed to categorize and add properties
from completely different objects with only about 20 lines of code. (These are
both examples in our EMF book - to be published Spring 2003.) Rather than
recommending people not use EMF.Edit, lets try the more constructive approach of
making GEF work with it.
Frank.
> > Hi,
> > Regards,
> > Eric Suen
Re: The Command in GEF & EMF [message #51706 is a reply to message #51310] Mon, 30 December 2002 14:30 Go to previous messageGo to next message
Originally posted by: julien.omondo.com
Hi all,
Frank Budinsky wrote:
> Randy,
this
sure
> stack.
Frank is correct. Right now we didn't support undo/redo on EMF model.
or
> Frank.
That will be very helpful.
Julien
omondo
> > > Hi,
> > > Regards
> > > Eric Suen
Re: The Command in GEF & EMF [message #52302 is a reply to message #51365] Sat, 04 January 2003 18:04 Go to previous messageGo to next message
corresponding
easier
To truly understand the runtime environment it is definitely worth while to
hand code an addition to the package. I just finished writing code to add an
import command to my editor. I did it step by step, first modifying the
toolbar, then creating an ActionItem, then creating an ImportCommand then
dealing with the execution. At each iteration I stepped through the EMF
chain to see what was happening by default if I didn't provide an override.
It gave me a much better feeling for what was going on behind the scenes. It
turns out that for my special case the call chain was much longer than
necessary but I got a better feeling for what can be overridden.
Re: The Command in GEF & EMF [message #56862 is a reply to message #51310] Tue, 21 January 2003 11:14 Go to previous messageGo to next message
Will this package available soon?
Thanks.
"Frank Budinsky" <frankb@ca.ibm.com> wrote in message
news:3E0C7A28.19F7EDA1@ca.ibm.com...
gef_for_emf.zip, or
command
> Frank.
are
> > > Hi,
presentation,
have
merge
> > > Regards
> > > Eric Suen
Re: The Command in GEF & EMF [message #56988 is a reply to message #51310] Wed, 22 January 2003 01:31 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.planet-wagenknecht.de
Hi!
"Frank Budinsky" <frankb@ca.ibm.com> schrieb im Newsbeitrag
gef_for_emf.zip, or
command
Why? How about make a seperate "command" package that can be shared not only
between GEF and EMF? It can be publicized via an "Eclipse Common Tools"
page.
It's always the same. There are a lot of good implementations in several
Eclipse plugins and every plugin copies the code insted of sharing it. It's
really anoying. Look into CDT and JDT they have complete redundant UI
packaged which could be really helpfull for other developers.
Cu, Gunnar
Re: The Command in GEF & EMF [message #57016 is a reply to message #56988] Wed, 22 January 2003 01:38 Go to previous messageGo to next message
http://dev.eclipse.org/bugs/show_bug.cgi?id=29939
Cu, Gunnar
Re: The Command in GEF & EMF [message #57126 is a reply to message #56988] Wed, 22 January 2003 14:25 Go to previous message
Gunnar,
I agree with you. We are starting to discuss the possibility of moving the
command package to a common eclipse plugin.
Frank.
Gunnar Wagenknecht wrote:
> Hi!
> gef_for_emf.zip, or
> command
> page.
> Cu, Gunnar
Previous Topic:ContextMenu
Next Topic:Anyone tried Java2D and SVG with SWT/Draw2D?
Current Time: Fri Nov 07 15:53:58 EST 2025
Powered by FUDForum. Page generated in 0.04922 seconds
