Home » Modeling » TMF (Xtext) » Errors in Xtext Grammar File
Errors in Xtext Grammar File [message #50944] Sat, 13 June 2009 16:04 Go to next message
Originally posted by: oba.informatik.uni-kiel.de
in the grammar editor of Xtext, some obvious errors are not shown.
Additionally, some errors are shown sometimes but not shown after a few
minutes although they are not fixed yet.
I have seen that there was a bug report regarding this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203671
Unfortunately, I can't deduce anything from that reports... What is the
current status? Will this bug in the editor be fixed soon?
What would I need to do and where would I need to start if I wanted to
fix it myself?
Example:
Rule :
Rule1 | Rule2
Rule 1:
lala=ID
Rule 1:
lala=ID
There are at least two bugs in the grammer above. These errors are
sometimes shown sometimes not..
Inanc
Re: Errors in Xtext Grammar File [message #51000 is a reply to message #50944] Sat, 13 June 2009 16:08 Go to previous messageGo to next message
Do you refer to oAW Xtext or TMF Xtext?
Looks like oAW Xtext as the grammar definition is missing in your
example grammar.
Sven
myName schrieb:
> fix it myself?
> Example:
> Rule :
> Rule1 | Rule2
> Rule 1:
> lala=ID
> Rule 1:
> lala=ID
> Thanks
> Inanc
Re: Errors in Xtext Grammar File [message #51028 is a reply to message #50944] Sat, 13 June 2009 16:08 Go to previous messageGo to next message
myName wrote:
I mean oAW Xtext.
Re: Errors in Xtext Grammar File [message #51056 is a reply to message #51028] Sun, 14 June 2009 09:42 Go to previous messageGo to next message
So the answer is, yes, it has been fixed in TMF Xtext. :-)
Sven
myName schrieb:
> myName wrote:
> I mean oAW Xtext.
Re: Errors in Xtext Grammar File [message #51112 is a reply to message #51056] Sun, 14 June 2009 10:20 Go to previous messageGo to next message
Thanks for your answer, Sven.
Well, the thing is: In the getting started documentation of TMF Xtext,
it says, that TMF Xtext needs Eclipse Galileo.
I am working on a project where we develop in Eclipse Ganymede. Can you
say anything about that?
- How compatible is TMF Xtext in Eclipse Ganymede? Do I "loose" any
features or so?
Re: Errors in Xtext Grammar File [message #51138 is a reply to message #51112] Sun, 14 June 2009 10:31 Go to previous messageGo to next message
It won't work, because the OSGi bundles explicitly require eclipse
galileo bundles (via version ranges).
Sven
> features or so?
> Thanks
Re: Errors in Xtext Grammar File [message #51165 is a reply to message #51112] Sun, 14 June 2009 10:33 Go to previous messageGo to next message
Hi myname,
I'm afraid you cannot use Xtext with Ganymede as we depend on EMF 2.5
which in turn requires Eclipse 3.5 Galileo.
The only way to overcome this is to compile EMF and Xtext yourself which
will propably no valid option for you.
Sebastian
Am 14.06.2009 16:20 Uhr, schrieb myName:
> features or so?
> Thanks
Re: Errors in Xtext Grammar File [message #51218 is a reply to message #51138] Sun, 14 June 2009 11:01 Go to previous message
oh, thanks.
Previous Topic:TMF Xtext Getting Started Example
Next Topic:[Xtext] Code Formatting via menu, but "Source" menu is not present
Current Time: Sun Nov 09 01:32:11 EST 2025
Powered by FUDForum. Page generated in 0.05161 seconds
