Home » Archived » M2M (model-to-model transformation) » [ATL] how can I reference a remote metamodel
[ATL] how can I reference a remote metamodel [message #50905] Thu, 05 July 2007 17:44 Go to next message
Originally posted by: heggly.gmx.net
Hi again,
in my rule I am trying to add an ESuperType, something like:
u : MOF!EClass
name <- 'Composer',
eSuperTypes <- Supertype
The problem is that the supertype does not exist in my curent package but on
a remote server, so what I actually want to do is add a kind of reference to
that "remote" EClass.
The ECore file genereated should look like:
<eClassifiers xsi:type="ecore:EClass" name="Composer"
eSuperTypes="http://www.remoteaddress/mm.ecore#//Supertype">
</eClassifiers>
maybe something like
eSuperTypes <- remoteAddress::Supertype
Is that possible? Do I have to specify the remote model as a "IN" model?
I saw the "Metamodel by URI" option in the eclipse run configuration but I
dont have any concrete input model that is conform to that remote metamodel
(which I think I would have to specify).
Thanks!
Felix.
Re: [ATL] how can I reference a remote metamodel [message #50961 is a reply to message #50905] Fri, 06 July 2007 07:19 Go to previous messageGo to next message
> u : MOF!EClass
> name <- 'Composer',
but on
reference to
> </eClassifiers>
but I
metamodel
You need to load the metamodel as a source model (conforming to Ecore).
Then you navigate it to get the class you want.
Of course, this scenario can only work if you "allow inter-model
references" in the advanced tab of the launch config.
Frédéric Jouault
Re: [ATL] how can I reference a remote metamodel [message #51017 is a reply to message #50961] Fri, 06 July 2007 07:46 Go to previous messageGo to next message
"Fr
Re: [ATL] how can I reference a remote metamodel [message #51157 is a reply to message #51017] Fri, 06 July 2007 11:25 Go to previous message
There are several things you can do, for instance:
- use ant tasks, which should allow you to load a source model by URI
(cf., http://wiki.eclipse.org/index.php/AM3_Ant_Tasks)
- improve the launch config so that it allows "metamodel by uri" also
for models conforming to the metametamodel (e.g., when their metamodel
is #EMF), and submit the patch via bugzilla
- load a dummy model conforming to your "remote" metamodel, so that you
load it as a source metamodel
Frédéric Jouault
Felix Förster wrote:
> "Frédéric Jouault" <frederic.jouault@univ-nantes.fr> schrieb im Newsbeitrag
> news:f6l8g0$lh4$1@build.eclipse.org...
>> Hello,
>>> u : MOF!EClass
>>> name <- 'Composer',
>> but on
>> reference to
>>> </eClassifiers>
>> but I
>> metamodel
> I tried that but
> loading the remote model as a source model (with metamodel Ecore) does not
> work since the button "Metamodel by URI" only works for metamodels, not for
> models. The error: "The action is only available on metamodel"
> Anything else I can do?
>> Regards,
>> Frédéric Jouault
Previous Topic:[ATL] combined rules don't work
Next Topic:Apply Profiles to UML models?
Current Time: Fri Jul 11 22:47:22 EDT 2025
Powered by FUDForum. Page generated in 0.09482 seconds
