Home » Eclipse Projects » Mylyn » Bugzilla bugs with non-ascii characters - encoding problem?
Bugzilla bugs with non-ascii characters - encoding problem? [message #50892] Thu, 26 June 2008 12:03 Go to next message
Originally posted by: jeffreyz.q-free.com
When I view a Bugzilla bug with Mylyn 3.0, all occurances of non-ascii
characters (in my case the Norwegian characters æ, ø and å), appear
garbled.
(I assume/hope that everyone who reads this e-mail will do so via a
piece of software that employs the correct encoding, and therefore my
examples here will make sense)
For example, the Mylyn task editor displays the following:
"Vedrørende separate rapporter:
Er det ok at vi i første omgang deler den opp ved å ta sideskift
før neste kontonr?"
The original (correct) text is:
Er det ok at vi i første omgang deler den opp ved å ta sideskift før
neste kontonr?"
Clearly there is an encoding problem somewhere. Although the garbled
version is displayed in the Mylyn task editor, the *correct* text is
displayed when the same bug is displayed by the internal Eclipse web
browser.
So Eclipse's internal web browser does not have a problem with the
encoding - only the Mylyn task editor does.
Assuming that this is an ecoding problem, where can the correct encoding
be specified so that the correct text is displayed? I am using Mylyn to
handle customer submitted bugs and the current situation does not look
very professional.
I understand the concept of encodings, but it is often confusing to
determine exactly where the wrong encoding is being used, and sometimes
even more difficult to determine how to correct it.
I would greatly appreciate some help here.
Jeffrey
Re: Bugzilla bugs with non-ascii characters - encoding problem? [message #51114 is a reply to message #50892] Fri, 27 June 2008 16:32 Go to previous message
You can configure the encoding if from the properties of your Bugzilla
repository in the Task Repositories view. The setting is in the "Additional
Settings" section:
http://wiki.eclipse.org/index.php/Mylyn_FAQ#Why_am_I_seeing_ strange_boxes_where_I_expect_to_see_proper_characters.3F
Steffen
Re: Bugzilla bugs with non-ascii characters - encoding problem? [message #590506 is a reply to message #50892] Fri, 27 June 2008 16:32 Go to previous message
Settings" section:
Steffen
Previous Topic:Trac Connector for Mylyn 3.0
Next Topic:Mylyn as a todo-list and more
Current Time: Thu Oct 09 17:51:28 EDT 2025
Powered by FUDForum. Page generated in 0.03169 seconds
