| Home » Eclipse Projects » Nebula » [Composite Table] Mac Drag and Drop
 Goto Forum:|
| [Composite Table] Mac Drag and Drop [message #50845] | Thu, 20 March 2008 12:10  |  |
| Eclipse User  |  |  |  |  | Originally posted by: michaely.i9technologies.com
 I have an application that utilizes Composite Tables as well as drag and
 drop functionality into those tables. Everything works fine in Windows
 and Linux but I cannot drag and drop into the Composite Tables in Mac.
 I have found the issue to be related to how OSX handles the
 DropTargetListener.
 In general if I have a parent composite with a child composite within it
 and I set the dropTarget on the parent composite, in Windows and
 Linux i can drop something on the child composite and the DropTarget
 will activate. This is not the case on OSX. You have to explicitly place
 the DropTargetListener on the child composite.
 Now my issues is that i cannot find which element of the Composite table
 to put the listener on so it will work in OSX. I have tried my Class
 that inherits from Composite Table, the row class, the header class, and
 i have called getChildren() on my main inheriting class and placed the
 listener on each child control that was returned. The children that were
 returned happened to be a Row, Header, and an InnerCompositeTable.
 Nothing worked.
 Does anyone have any insight into this issue. Any help would be greatly
 appreciated.
 Thank You,
 Mike
| Re: [Composite Table] Mac Drag and Drop [message #50901 is a reply to message #50845] | Sat, 22 March 2008 15:11   |  |
| Eclipse User  |  |  |  |  | Hi,
 I don't have a Mac to debug this; any help from the community would be
 really appreciated.
 You could also try to produce a snippet independent of CompositeTable
 that reproduces the behavior and file a bug against Platform/SWT.
 Dave Orme
 On Thu, 2008-03-20 at 10:10 -0600, Michael Yara wrote:
 > Hello,
 > DropTargetListener.
 > Nothing worked.
 > appreciated.
 > Thank You,
 > Mike
| Re: [Composite Table] Mac Drag and Drop [message #50958 is a reply to message #50901] | Mon, 24 March 2008 12:48  |  |
| Eclipse User  |  |  |  |  | Please provide a snippet and I'll help Dave to track down the problem.
 Tom
 Dave Orme schrieb:
 > really appreciated.
 > Best regards,
 > Dave Orme
 >> Hello,
 >> DropTargetListener.
 >> Nothing worked.
 >> appreciated.
 >> Thank You,
 >> Mike
 B e s t S o l u t i o n . at
 Tom Schindl                                          JFace-Committer
| Re: [Composite Table] Mac Drag and Drop [message #589091 is a reply to message #50845] | Sat, 22 March 2008 15:11  |  |
 really appreciated.
 Dave Orme
 > Hello,
 > DropTargetListener.
 > Nothing worked.
 > appreciated.
 > Thank You,
 > Mike
| Re: [Composite Table] Mac Drag and Drop [message #589106 is a reply to message #50901] | Mon, 24 March 2008 12:48  |  |
 Tom
 Dave Orme schrieb:
 > really appreciated.
 > Best regards,
 > Dave Orme
 >> Hello,
 >> DropTargetListener.
 >> Nothing worked.
 >> appreciated.
 >> Thank You,
 >> Mike
 Current Time: Fri Oct 31 14:01:02 EDT 2025
 Powered by FUDForum . Page generated in 0.03733 seconds |
