Home » Eclipse Projects » Nebula » [Composite Table] Mac Drag and Drop
| [Composite Table] Mac Drag and Drop [message #50845] |
Thu, 20 March 2008 12:10  |
Originally posted by: michaely.i9technologies.com
I have an application that utilizes Composite Tables as well as drag and
drop functionality into those tables. Everything works fine in Windows
and Linux but I cannot drag and drop into the Composite Tables in Mac.
I have found the issue to be related to how OSX handles the
DropTargetListener.
In general if I have a parent composite with a child composite within it
and I set the dropTarget on the parent composite, in Windows and
Linux i can drop something on the child composite and the DropTarget
will activate. This is not the case on OSX. You have to explicitly place
the DropTargetListener on the child composite.
Now my issues is that i cannot find which element of the Composite table
to put the listener on so it will work in OSX. I have tried my Class
that inherits from Composite Table, the row class, the header class, and
i have called getChildren() on my main inheriting class and placed the
listener on each child control that was returned. The children that were
returned happened to be a Row, Header, and an InnerCompositeTable.
Nothing worked.
Does anyone have any insight into this issue. Any help would be greatly
appreciated.
Thank You,
Mike
| Re: [Composite Table] Mac Drag and Drop [message #50901 is a reply to message #50845] |
Sat, 22 March 2008 15:11   |
I don't have a Mac to debug this; any help from the community would be
really appreciated.
You could also try to produce a snippet independent of CompositeTable
that reproduces the behavior and file a bug against Platform/SWT.
Dave Orme
On Thu, 2008-03-20 at 10:10 -0600, Michael Yara wrote:
> Hello,
> DropTargetListener.
> Nothing worked.
> appreciated.
> Thank You,
> Mike
| Re: [Composite Table] Mac Drag and Drop [message #50958 is a reply to message #50901] |
Mon, 24 March 2008 12:48  |
Please provide a snippet and I'll help Dave to track down the problem.
Tom
Dave Orme schrieb:
> really appreciated.
> Best regards,
> Dave Orme
>> Hello,
>> DropTargetListener.
>> Nothing worked.
>> appreciated.
>> Thank You,
>> Mike
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: [Composite Table] Mac Drag and Drop [message #589091 is a reply to message #50845] |
really appreciated.
Dave Orme
> Hello,
> DropTargetListener.
> Nothing worked.
> appreciated.
> Thank You,
> Mike
| Re: [Composite Table] Mac Drag and Drop [message #589106 is a reply to message #50901] |
Tom
Dave Orme schrieb:
> really appreciated.
> Best regards,
> Dave Orme
>> Hello,
>> DropTargetListener.
>> Nothing worked.
>> appreciated.
>> Thank You,
>> Mike
Current Time: Fri Nov 07 13:34:27 EST 2025
Powered by FUDForum. Page generated in 0.03642 seconds
