Home » Newcomers » Newcomers » Error when opening build.xml
Error when opening build.xml [message #50809] Mon, 11 April 2005 19:07 Go to next message
Originally posted by: ppine7.netscape.net
I'm trying to open a build file, build.xml, in Eclipse , and I'm getting
the following error:
"An error has occured while creating this editor"
This happens in one project only (other projects have no trouble opening
ANT scripts), and with the build.xml file only (I have another build file
there, buildJ2EE.xml, which is opened just fine).
I tried removing this build.xml and replacing it with another "good" file,
closing and re-opening the project, but nothing helps - Eclipse always
breaks when I'm trying to open this file.
Any idea what's going on?
Thanks!
Marina
Re: Error when opening build.xml [message #50924 is a reply to message #50809] Tue, 12 April 2005 01:42 Go to previous messageGo to next message
Can you check your error log:
Window>Show View>Other>PDE Runtime>Error Log
and report the findings related to this probem?
Also always report which Eclipse you are using :-) Help>About Eclipse
platform>Build id
Darins
"Marina" <ppine7@netscape.net> wrote in message
news:b96edbeaef0dd5159a4660dea4d44131$1@www.eclipse.org...
> Thanks!
> Marina
Re: Error when opening build.xml [message #51718 is a reply to message #50924] Wed, 13 April 2005 11:39 Go to previous message
Hi, Darin,
I figured out what was wrong - one of the build tasks was calling a Jva
class with corrupted .class file...
Thanks for your response!
Marina
Previous Topic:Internal Error Launching Debugger
Next Topic:Rename
Current Time: Tue Nov 18 05:10:28 EST 2025
Powered by FUDForum. Page generated in 0.07447 seconds
