Home » Eclipse Projects » Eclipse Platform » File corruption, with Eclipse, CVS, Cygwin
File corruption, with Eclipse, CVS, Cygwin [message #50808] Tue, 27 May 2003 20:22 Go to next message
Originally posted by: matthew.sinclair.distra.com
I am trying to track down a file corruption problem that (I think) has
something to do with the interplay of Eclipse, CVS and Cygwin. I have
already sent a message to the Cygwin group, but to no avail. I am not
entirely sure that the problem relates to Eclipse, but I have only noticed
it since using the Eclipse 'Team' feature to share a CVS repository.
I am using the following CygWin config, under Windows XP:
$ uname -a
CYGWIN_NT-5.1 mattspc 1.3.22(0.78/3/2) 2003-03-18 09:20 i686 unknown unknown
Cygwin
$ cvs -version
Concurrent Versions System (CVS) 1.11 (client/server) ...
$ ssh -V
OpenSSH_3.6.1p1, SSH protocols 1.5/2.0, OpenSSL 0x0090702f
$ env | grep CVS
CVSEDITOR=vi
CVSIGNORE=*.dll *.jar *.class *.war .nbattrs tmp CVS CVSROOT .classpath_pre
..classpath_post
CVSROOT=:ext:office:/secure/development/...
CVS_RSH=ssh
$ env | grep CYG
CYGWIN=nontsec nosmbntsec
I recently switched over from using a simple file based cvs repository
(located on a Linux box, shared thru Samba) to use the :ext: method with
ssh. I did this so that I could use the 'team' features of Eclipse and use
CVS through the Eclipse GUI. I also recently upgraded cygwin using the
standard setup.exe update procedure.
One of these things is causing me serious grief in terms of file corruption
for files checked in and out of the cvs repository. I initially thought that
the problem was Eclipse, after seeing a few comments in lists to that
effect, but I have now stopped using it's 'team' features, exclusively using
cvs from the command line, however I
am still getting random corruption of files. I really wish I could isolate
the problem and describe a scenario in which it occurs, but I have not been
able to repeatably get the problem to occur. About the only thing I can pin
down is that I seem to notice the corruption first thing in the morning,
after logging back in.
For example, I will work all day without problems, checking in, updating,
etc, etc, across multiple CVS repositories. I then pack up to go home, close
my machine and reboot. When I get back the next day, log in, and start to
work, I will notice that some of the files that I have had checked out, and
modified, but not checked back in, will have been completely garbled. If I
remove the file, and cvs update, I get a fresh
uncorrupted copy from the repository (as of the last check in). The problem
does not happen for non-repository files.
It is really driving me crazy, because it has caused me to lose work on
several occasions, and I cannot seem to be able to work out precisely what
it causing it so that I can quarantine the tool or process.
Any help would be much appreciated.
M@
Re: File corruption, with Eclipse, CVS, Cygwin [message #51652 is a reply to message #50808] Wed, 28 May 2003 08:21 Go to previous messageGo to next message
Originally posted by: boris.litvak.lycos.com
Hi Matthew,
I'm having a similar problem on Win2000. I mark all the files that are
added/deleted using cygwin, but I check in using cmd.exe. This usually
works,
though sometimes when I try to update from CVS, nothing is done and there
is no notification.
Developer.
Re: File corruption, with Eclipse, CVS, Cygwin [message #51687 is a reply to message #50808] Wed, 28 May 2003 09:12 Go to previous messageGo to next message
Originally posted by: Michael_Valenta.oti.com
The main cause of file corruptions with CVS in Eclipse has been
improperly configured files on the server. If a file contain binary data
it must have a keyword substitution mode of -kb or the client is free to
translate LFs into CRLFs or whatever the platform line ending is. Do the
files being corrupted contain binary data and are they marked as -kb on
the server?
Michael
> $ uname -a
> Cygwin
> $ cvs -version
> $ ssh -V
> $ env | grep CVS
> CVSEDITOR=vi
> .classpath_post
> CVS_RSH=ssh
> $ env | grep CYG
> Cheers,
> M@
Re: File corruption, with Eclipse, CVS, Cygwin [message #52026 is a reply to message #51687] Wed, 28 May 2003 10:49 Go to previous messageGo to next message
Not in my case, I'm aware of this option.
Re: File corruption, with Eclipse, CVS, Cygwin [message #53959 is a reply to message #52026] Thu, 29 May 2003 10:22 Go to previous messageGo to next message
The other possibility is the use of the Cygwin ssh client. I seem to
recall problems in the past with this client. You could try another SSH
client (like putty/plink).
Re: File corruption, with Eclipse, CVS, Cygwin [message #58344 is a reply to message #51687] Sun, 01 June 2003 20:10 Go to previous messageGo to next message
No, I don't think -kb is the problem. All of the corrupted files are just
plain old vanilla Java source files. I use Unix-style files (rather than DOS
cr/lf).
M@
Re: File corruption, with Eclipse, CVS, Cygwin [message #58408 is a reply to message #53959] Sun, 01 June 2003 21:52 Go to previous message
I suspect that you might be right on the Cygwin/SSH front. I've installed
putty, and it works fine, except when I try to actually do anything with
CVS. For example, the following occurs when I do a cvs -n update:
$ cvs -n update
cvs [update aborted]: cannot exec plink -ssh -i
c:/Devel/opt/PuTTY/keys/mfs.PPK: No such file or directory
cvs [update aborted]: end of file from server (consult above messages if
any)
Even though, it appears to work raw:
$ echo $CVS_RSH
plink -ssh -i c:/Devel/opt/PuTTY/keys/mfs.PPK
$ $CVS_RSH -l matts office
Sent username "matts"
Last login: Mon Jun 2 11:44:39 2003 from 192.168.1.240
Have a lot of fun...
Hmmm ...
Previous Topic:RedHat 9 launcher crash
Next Topic:CVS ignores $Date$
Current Time: Sun Nov 09 12:25:00 EST 2025
Powered by FUDForum. Page generated in 0.04850 seconds
