Home » Eclipse Projects » Mylyn » Problem creating query
Problem creating query [message #50806] Thu, 26 June 2008 04:10 Go to next message
Originally posted by: cbruemmer.axway.com
Hi all,
I just installed Eclipse Ganymede and wanted to try out Mylyn.
I created a new task repository and upon hitting the button the
credentials validate just fine. But when I try to create a new query a
popup showing the bugzilla website comes up and the header reads: 'Error
updating search options'.
Hitting the 'ok'-button I get an error popup saying 'Unable to get
configuration'.
Bugzilla version is 2.22.1-debian2.
Any hints appreciated.
Re: Problem creating query [message #51170 is a reply to message #50806] Fri, 27 June 2008 16:49 Go to previous messageGo to next message
Originally posted by: rob.elves.eclipse.org
Hi Chris,
Please try updating your repository configuration. To do so, open the
Task Repositories (accessible via the Task List's view dropdown menu)
and right click on the repository in question and select Update
Repository Configuration? Once complete, try creating a query. If the
update causes errors, check the error log and consider posting a new bug
report along with the error.
-Rob
Chris Bruemmer wrote:
> Hi all,
> configuration'.
Re: Problem creating query [message #51440 is a reply to message #51170] Mon, 30 June 2008 03:27 Go to previous messageGo to next message
Ok, did this.
Got a popup showing the bugzilla gui again and stating 'Error updating
repository configuration'.
No errors show up in the error log ...
Re: Problem creating query [message #54214 is a reply to message #51440] Mon, 21 July 2008 21:35 Go to previous message
Hi, Chris
Did you get any feedback for this issue?
(I have similar issue with same version of bugzilla)
Re: Problem creating query [message #590537 is a reply to message #50806] Fri, 27 June 2008 16:49 Go to previous message
Hi Chris,
-Rob
> Hi all,
> configuration'.
Re: Problem creating query [message #590678 is a reply to message #51170] Mon, 30 June 2008 03:27 Go to previous message
Ok, did this.
Re: Problem creating query [message #591763 is a reply to message #51440] Mon, 21 July 2008 21:35 Go to previous message
Hi, Chris
Previous Topic:Mylyn 3.0 is available
Next Topic:Printing tasks
Current Time: Sun Nov 09 02:13:04 EST 2025
Powered by FUDForum. Page generated in 0.03102 seconds
