bug 92163 ? [message #50778] |
Fri, 22 April 2005 08:05  |
Any clue what might be the problem here. I'm essentially locked out of using ADJT, and I'm starting to get the shakes.
thanks!
-barry
Re: bug 92163 ? [message #50915 is a reply to message #50805] |
Fri, 22 April 2005 11:37  |
Sian January wrote:
> Hi Barry,
> Would you be able to try this with the latest development build and let
> us know if you still have the problem?
Do you mean 1.2.0.20050420095141? If so, that is what I was using.
-barry
Re: bug 92163 ? [message #587783 is a reply to message #50778] |
Fri, 22 April 2005 08:56  |
Hi Barry,
us know if you still have the problem? The code that appeared to
produce that exception has been completely overhauled this week so
hopefully the latest build should fix your problem. Development builds
are available from the AJDT download page:
http://www.eclipse.org/ajdt/download.html
Sian
> thanks!
> -barry
Re: bug 92163 ? [message #587813 is a reply to message #50805] |
Fri, 22 April 2005 11:30  |
Yes, I'll try and let you know. Thanks.
-barry
Re: bug 92163 ? [message #587816 is a reply to message #50805] |
Fri, 22 April 2005 11:35  |
Sian January wrote:
> Hi Barry,
This version is for 3.1M6?
-barry
Re: bug 92163 ? [message #587824 is a reply to message #50805] |
Sian January wrote:
> Hi Barry,
-barry
FUDForum. Page generated in 0.28432 seconds
