Home » Eclipse Projects » Mylyn » Mylyn 3.0 is available
| Re: Mylyn 3.0 is available [message #50922 is a reply to message #50775] |
Fri, 27 June 2008 01:53   |
"Mik Kersten" <mik.kersten@tasktop.com> wrote in message
news:g3uo5m$b8t$1@build.eclipse.org...
> We are very pleased to announce that Mylyn 3.0 is now available for
> Eclipse 3.4 and 3.3.
Great job, thank you!
I'm having a bit of trouble getting Mylyn 3 installed into Ganymede.
I downloaded this: eclipse-SDK-3.4-win32.zip (for my XP Pro rig)
Unzipped it.
In the available software tab of the Software Updates and Add-ons dialog I
select Collaboration Tools
Click install
Get these errors:
Cannot complete the request. See the details.
Unsatisfied dependency: [org.eclipse.mylyn.ide.ui 3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0)
Cannot find a solution where both Match[requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.4.0,4.0.0)] and Match[requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0)] can be satisfied.
Unsatisfied dependency: [org.eclipse.mylyn.pde.ui 3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.pde.ui/[3.3.0,3.4.0)
osgi.bundle/org.eclipse.pde.ui/[3.4.0,4.0.0)] and Match[requiredCapability:
osgi.bundle/org.eclipse.pde.ui/[3.3.0,3.4.0)] can be satisfied.
Unsatisfied dependency: [org.eclipse.mylyn.ide.ant 3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.mylyn.ide.ui/[3.0.0,4.0.0)
Unsatisfied dependency: [org.eclipse.mylyn.java_feature.feature.group
3.0.0.v20080619-1900] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide.ui/[3.0.0,4. 0.0)
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java.ui/[3.0.0.v 20080619-1900,3.0.0.v20080619-1900]
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide.ui/[3.0.0.v2 0080619-1900,3.0.0.v20080619-1900]
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide.ant/[3.0.0.v 20080619-1900,3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.mylyn.java.ui/0.0.0
requiredCapability: osgi.bundle/org.eclipse.mylyn.java.ui/[3.0.0,4.0.0)
Unsatisfied dependency: [org.eclipse.mylyn.ide_feature.feature.group
Unsatisfied dependency: [org.eclipse.mylyn.java.ui 3.0.0.v20080619-1900]
Unsatisfied dependency: [org.eclipse.mylyn.pde_feature.feature.group
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java.ui/[3.0.0,4 .0.0)
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.pde.ui/[3.0.0.v2 0080619-1900,3.0.0.v20080619-1900]
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java_feature.fea ture.group/[3.0.0.v20080619-1900,3.0.0.v20080619-1900]
I get similar results when I go to my previous eclipse installation and try
to update from Mylyn 2.3.0
Is there a work around?
| Re: Mylyn 3.0 is available [message #51035 is a reply to message #50950] |
Fri, 27 June 2008 16:24  |
>> Unzipped it.
>> I select Collaboration Tools
>> Click install
> Actually, in this description of what I did, left out some other plug
> installs. If I start from a clean Ganymede install, the installation goes
> perfectly.
Tom, do you have a sense which plug-ins caused the conflict? For most
integrations such as Subversive, Subclipse or Spring IDE updates have been
released that support Mylyn 3.0 but you may need to update those as well
when updating Mylyn.
Steffen
| Re: Mylyn 3.0 is available [message #590432 is a reply to message #50775] |
Unzipped it.
Click install
Get these errors:
| Re: Mylyn 3.0 is available [message #590442 is a reply to message #50922] |
Fri, 27 June 2008 02:18  |
> Unzipped it.
> Click install
perfectly.
| Re: Mylyn 3.0 is available [message #590473 is a reply to message #50950] |
>> Unzipped it.
>> Click install
> perfectly.
Steffen
Current Time: Mon Nov 10 17:58:22 EST 2025
Powered by FUDForum. Page generated in 0.04566 seconds
