Home » Eclipse Projects » Plugin Development Environment (PDE) » how to run bash script programmatically from eclipse plugin
how to run bash script programmatically from eclipse plugin [message #50747] Wed, 18 March 2009 10:06 Go to next message
how can i run bash script programmtically from eclipse plugin.
I tried using java runtime, but it does not work. The script is working
when called from command line or simple java application.
Runtime.getRuntime().exec(new String{"/home/script.sh","param1","param2"});
regards,
Sana.
Re: how to run bash script programmatically from eclipse plugin [message #50862 is a reply to message #50747] Wed, 18 March 2009 14:38 Go to previous messageGo to next message
Sana wrote:
Sana wrote:
> Hi
> regards,
> Sana.
> Hi
> regards,
> Sana.
From my experience on windows, you will probably have to prefix
"/bin/bash" before your command.
Runtime.getRuntime().exec(new String{"/bin/bash",
Re: how to run bash script programmatically from eclipse plugin [message #51031 is a reply to message #50862] Thu, 19 March 2009 09:27 Go to previous messageGo to next message
Well, on linux, it does not seem to work. Infact ,if i ask for return
value of this subprocess, the process throws
java.lang.IllegalThreadStateException process has not exited.
try{
Runtime r = Runtime.getRuntime();
Process proc = r.exec(new
String{"/bin/sh","/home/script.sh","param1","param2"});
int exit_val = proc.exitValue();
}catch(Exception e){
e.printStackTrace();
thanks for any help,
Re: how to run bash script programmatically from eclipse plugin [message #51092 is a reply to message #51031] Thu, 19 March 2009 09:38 Go to previous message
Hello.
The API documentation states that it behaves like that:
http://java.sun.com/javase/6/docs/api/java/lang/Process.html #exitValue()
Maybe add a call to waitFor() before calling exitValue().
With best regards
Clemens Anhuth
www.froglogic.com - Squish - Multi-Platform GUI Testing
Re: how to run bash script programmatically from eclipse plugin [message #593393 is a reply to message #50747] Wed, 18 March 2009 14:38 Go to previous message
Sana wrote:
Sana wrote:
> Hi
> regards,
> Sana.
> Hi
> regards,
> Sana.
Re: how to run bash script programmatically from eclipse plugin [message #593476 is a reply to message #50862] Thu, 19 March 2009 09:27 Go to previous message
try{
Re: how to run bash script programmatically from eclipse plugin [message #593528 is a reply to message #51031] Thu, 19 March 2009 09:38 Go to previous message
Hello.
With best regards
Clemens Anhuth
Previous Topic:[Jade] Can't get a proxy to the Platform Manager
Next Topic:External Content Assist for all editors?
Current Time: Sat Nov 08 22:49:30 EST 2025
Powered by FUDForum. Page generated in 0.04591 seconds
