Home » Modeling » TMF (Xtext) » Importing a grammar which inturn has imported a Metamodel
Importing a grammar which inturn has imported a Metamodel [message #50739] Fri, 12 June 2009 13:12 Go to next message
Hello All
I am tryin to write a grammar(say gr_1) that has imported another
Grammar(gr_2).
However gr_2 has also imported Metamodel say m_1.
So does using rules of gr_1 in gr_2 valid in the XText?
->Moreover I have suppressed the generation of Metamodel in gr_1.
Can't get it working!!
My implm is somewhat like this:
------------------------------gr_2-----------------------
grammar org.xtext.example.MyDsl4 with org.xtext.samm_dsl.Edifice
generate myDsl4 "http://www.xtext.org/example/MyDsl4"
Core:
('Entity:'core_elem+=MemoryDescriptor)*
---------------------------gr_1----------------------------- ----
grammar org.xtext.samm_dsl.Edifice with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "http://q-impress.eu/samm/core" as refn_core
import "http://q-impress.eu/samm/datatype" as refn_datatypes
import "http://q-impress.eu/samm/deployment/targetenvironment" as
refn_depl_targetenv
import "http://q-impress.eu/samm/deployment/hardware" as refn_depl_hardware
import "http://q-impress.eu/samm/deployment/allocation" as
refn_depl_allocation
import "http://q-impress.eu/samm/behaviour" as refn_behaviour
import "http://q-impress.eu/samm/usagemodel" as refn_usagemodel
import "http://q-impress.eu/samm/staticstructure" as refn_staticstructure
import "http://q-impress.eu/identifier" as ident
Identifier returns ident::Identifier :
Entity;
//This part pertains to Core classes
Entity returns refn_core::Entity:
(NamedEntity | Connector | EndPoint | HardwareDescriptor)
MemoryDescriptor returns refn_depl_hardware::MemoryDescriptor:
'MemoryDescriptor' 'id:' id=STRING '{'
//parent attrib(s)
'doc:' documentation=STRING';'
//class specific attributes
'bw:' bandwidth=INT ';'
'fsbFreq:' fsbFrequency=INT ';'
'accessFreq:' accessLatency=INT ';'
'burstLen:' burstLength=INT ';'
shows the following error when I run workflow for gr_2
4793 [main] ERROR enerator.CompositeGeneratorFragment -
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependencyHelper.handle(GenPackageImpl.java:2373)
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependencyHelper.handle(GenPackageImpl.java:2362)
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependencyHelper. <init>(GenPackageImpl.java:2302)
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.p repareCache(GenPackageImpl.java:3090)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageG eneratorAdapter.doPreGenerate(GenPackageGeneratorAdapter.jav a:182)
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.preGenerate(AbstractGeneratorAdapter.java:256)
org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:609)
org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:528)
org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment.gen erateEcoreJavaClasses(EcoreGeneratorFragment.java:277)
org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment.gen erate(EcoreGeneratorFragment.java:106)
org.eclipse.xtext.generator.CompositeGeneratorFragment.gener ate(CompositeGeneratorFragment.java:77)
org.eclipse.xtext.generator.LanguageConfig.generate(Language Config.java:68)
at org.eclipse.xtext.generator.Generator.generate(Generator.jav a:269)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generat or.java:80)
org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:118)
org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
Entire console result:
0 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
18 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - EMF Modeling
Workflow Engine 0.7.0, Build v200905260637
18 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - (c) 2005-2009
openarchitectureware.org and contributors
18 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - running workflow:
C:/Users/Durga/workspace_TMF/org.xtext.example.mydsl4/src/or g/xtext/example/GenerateMyDsl4.mwe
19 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
559 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering
platform uri 'C:\Users\Durga\workspace_TMF'
700 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.staticstructure.StaticstructurePackage'
701 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.behaviour.BehaviourPackage'
702 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage
'eu.qimpress.samm.deployment.targetenvironment.Targetenviron mentPackage'
EPackage 'eu.qimpress.samm.deployment.hardware.HardwarePackage'
EPackage 'eu.qimpress.samm.deployment.allocation.AllocationPackage'
703 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.datatypes.DatatypesPackage'
EPackage 'eu.qimpress.samm.annotation.AnnotationPackage'
EPackage 'eu.qimpress.samm.usagemodel.UsagemodelPackage'
3082 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory '../org.xtext.example.mydsl4/src-gen'
3083 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
C:\Users\Durga\workspace_TMF\org.xtext.example.mydsl4\..\org .xtext.example.mydsl4\src-gen
3084 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory '../org.xtext.example.mydsl4.ui/src-gen'
3084 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
C:\Users\Durga\workspace_TMF\org.xtext.example.mydsl4\..\org .xtext.example.mydsl4.ui\src-gen
3085 [main] INFO e.core.container.CompositeComponent - Generator
3115 [main] INFO ipse.xtext.generator.LanguageConfig - generating
infrastructure for org.xtext.example.MyDsl4 with fragments :
ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment,
EcoreGeneratorFragment, ParseTreeConstructorFragment,
ResourceFactoryFragment, DelegatingGeneratorFragment,
JavaValidatorFragment, JavaScopingFragment, FormatterFragment,
LabelProviderFragment, TransformerFragment, JavaBasedContentAssistFragment
13763 [main] INFO or.validation.JavaValidatorFragment - executing
generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
13898 [main] DEBUG enerator.CompositeGeneratorFragment - replacing
binding :
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.ITok enColorer ->
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.ITok enColorer.NullTokenColorer
(contributed by org.eclipse.xtext.ui.generator.ImplicitUiFragment)
13898 [main] DEBUG enerator.CompositeGeneratorFragment - with new
binding :
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.Comm onAntlrTokenColorer
(contributed by de.itemis.xtext.antlr.XtextAntlrGeneratorFragment)
binding : org.eclipse.jface.text.rules.ITokenScanner ->
org.eclipse.xtext.ui.common.editor.syntaxcoloring.DefaultTok enScanner
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.Antl rTokenScanner
13899 [main] DEBUG enerator.CompositeGeneratorFragment - replacing
binding : org.eclipse.xtext.ui.core.editor.IDamagerRepairer ->
org.eclipse.xtext.ui.core.editor.FastLineBasedDamagerRepaire r (contributed
13899 [main] DEBUG enerator.CompositeGeneratorFragment - with new
org.eclipse.xtext.ui.core.editor.XtextDamagerRepairer (contributed by
binding : org.eclipse.jface.viewers.ILabelProvider ->
org.eclipse.xtext.ui.core.DefaultLabelProvider (contributed by
org.xtext.example.labeling.MyDsl4LabelProvider (contributed by
org.eclipse.xtext.ui.generator.labeling.LabelProviderFragmen t)
binding :
org.eclipse.xtext.ui.common.editor.outline.ISemanticModelTra nsformer ->
org.eclipse.xtext.ui.common.editor.outline.impl.DefaultSeman ticModelTransformer
binding :
org.xtext.example.outline.MyDsl4Transformer (contributed by
org.eclipse.xtext.ui.generator.outline.TransformerFragment)
binding :
org.eclipse.xtext.ui.core.editor.contentassist.IContentPropo salProvider ->
org.eclipse.xtext.common.contentassist.TerminalsProposalProv ider
binding :
org.xtext.example.contentassist.MyDsl4ProposalProvider (contributed by
org.eclipse.xtext.ui.generator.contentAssist.JavaBasedConten tAssistFragment)
14011 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - workflow
completed in 10930ms!
sry for posting all these long posts!!..
but I hope tht shall help u know my problem exactly.
Thanks.
Durga
Re: Importing a grammar which inturn has imported a Metamodel [message #50781 is a reply to message #50739] Fri, 12 June 2009 13:49 Go to previous messageGo to next message
I specified my grammar wrongly in my previous post.(just interchanged)
Sry. consider this..
Grammar(gr_2).
So is using rules of gr_2 in gr_1 valid this way in the XText?
->Moreover I have suppressed the generation of Metamodel in gr_2.
------------------------------gr_1-----------------------
Core:
---------------------------gr_2----------------------------- ----
refn_depl_targetenv
Entity; //This part pertains to Core classes
//parent attrib(s)
19 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - 559 [main] INFO
lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri
EPackage
binding :
binding :
binding :
binding :
binding :
binding :
Thanks.
Durga
Re: Importing a grammar which inturn has imported a Metamodel [message #50831 is a reply to message #50781] Fri, 12 June 2009 14:26 Go to previous messageGo to next message
Hi Durga,
please attach your mwe-file. I assume that you did not register your
imported metamodels in your workflow.
Thanks.
Sebastian
Am 12.06.2009 19:49 Uhr, schrieb Durga Prasana Sahoo:
> Grammar(gr_2).
> Core:
> refn_depl_targetenv
> //parent attrib(s)
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> EPackage
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> binding :
> binding :
> org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.Antl rTokenScanner (contributed
> binding :
> binding :
> binding :
> -> org.eclipse.xtext.common.contentassist.TerminalsProposalProv ider
> binding :
> -> org.xtext.example.contentassist.MyDsl4ProposalProvider (contributed
> by
> Thanks.
> Durga
Re: Importing a grammar which inturn has imported a Metamodel [message #51462 is a reply to message #50831] Mon, 15 June 2009 05:18 Go to previous messageGo to next message
Hello Sebastian
I indeed registered the generated EPackages in the mwe file.
The generate.mwe file for gr_1 is:
<workflow>
<property file="org/xtext/example/GenerateMyDsl4.properties"/>
<property name="runtimeProject" value="../${projectName}"/>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"
platformUri="${runtimeProject}/..">
<registerGeneratedEPackage
value="eu.qimpress.samm.staticstructure.StaticstructurePackage "/>
value="eu.qimpress.samm.behaviour.BehaviourPackage"/>
value=" eu.qimpress.samm.deployment.targetenvironment.Targetenvironm entPackage "/>
value="eu.qimpress.samm.deployment.hardware.HardwarePackage "/>
value="eu.qimpress.samm.deployment.allocation.AllocationPackage "/>
value="eu.qimpress.samm.datatypes.DatatypesPackage"/>
value="eu.qimpress.samm.annotation.AnnotationPackage"/>
value="eu.qimpress.samm.usagemodel.UsagemodelPackage"/>
value="eu.qimpress.identifier.IdentifierPackage"/>
</bean>
<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner"
directory="${runtimeProject}/src-gen"/>
directory="${runtimeProject}.ui/src-gen"/>
<component class="org.eclipse.xtext.generator.Generator">
<pathRtProject value="${runtimeProject}"/>
<pathUiProject value="${runtimeProject}.ui"/>
<projectNameRt value="${projectName}"/>
<projectNameUi value="${projectName}.ui"/>
<language uri="${grammarURI}" fileExtensions="${file.extensions}">
<!-- Java API to access grammar elements (required by several other
fragments) -->
<fragment
class=" org.eclipse.xtext.generator.grammarAccess.GrammarAccessFragm ent "/>
<!-- generates Java API for the generated EPackages -->
<fragment
class="org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment "/>
<!-- the serialization component -->
<fragment
class=" org.eclipse.xtext.generator.parseTreeConstructor.ParseTreeCo nstructorFragment "/>
<!-- a custom ResourceFactory for use with EMF -->
<fragment
class=" org.eclipse.xtext.generator.resourceFactory.ResourceFactoryF ragment "
fileExtensions="${file.extensions}"/>
<!-- the following fragment tries to use the Antlr Generator fragment
which can be downloaded from http://www.itemis.com
and falls back to the packrat parser if it's not available. -->
<fragment
class="org.eclipse.xtext.generator.DelegatingGeneratorFragment "
delegate="de.itemis.xtext.antlr.XtextAntlrGeneratorFragment "
message="You are generating without ANTLR. It is highly recommended to
download and use the plugin 'de.itemis.xtext.antlr' \n\t using the update
site http://xtext.itemis.com/updates/milestones.">
<fallback
class="org.eclipse.xtext.generator.parser.PackratParserFragment "/>
</fragment>
<!-- java-based API for validation -->
<fragment
class=" org.eclipse.xtext.generator.validation.JavaValidatorFragment ">
<composedCheck
value="org.eclipse.xtext.validation.ImportUriValidator"/>
</fragment>
<!-- scoping API -->
<fragment
class="org.eclipse.xtext.generator.scoping.JavaScopingFragment "/>
<!-- formatter API -->
<fragment
class="org.eclipse.xtext.generator.formatting.FormatterFragment "/>
<!-- labeling API -->
<fragment
class=" org.eclipse.xtext.ui.generator.labeling.LabelProviderFragmen t "/>
<!-- outline API -->
<fragment
class="org.eclipse.xtext.ui.generator.outline.TransformerFragment "/>
<!-- java-based API for content assistance -->
<fragment
class=" org.eclipse.xtext.ui.generator.contentAssist.JavaBasedConten tAssistFragment "/>
</language>
</component>
</workflow>
But the problem I guess is the inavailability of the following packages:
org.xtext.samm_dsl.edifice
org.xtext.samm_dsl.edifice.util
org.xtext.samm_dsl.edifice.impl
But these packages are indeed not intended to be generated Since, I've
suppressed the generation of ecore model for the edifice dsl.(gr_2)
Thanks.
Durga
Re: Importing a grammar which inturn has imported a Metamodel [message #51489 is a reply to message #50831] Mon, 15 June 2009 05:23 Go to previous messageGo to next message
Hello Sebastian
I'm really sry but I must say that the error I get is when I run the
workflow for gr_1( not gr_2).
I messed up the order of grammars!! sry..
Thanks.
Durga
Re: Importing a grammar which inturn has imported a Metamodel [message #51633 is a reply to message #51489] Mon, 15 June 2009 18:43 Go to previous message
Hi Durga,
I guess you did not suppress ecore-generation in the workflow file, that
finally fails with the exception trace that you posted originally.
Please try to establish references to the genmodels of the metamodels
that were imported in your base language. It can be done similar to the
following snippet:
<fragment class="org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment ">
<genmodels
value="platform:/resource/dontknowthepath/metamodel1.genmodel,
platform:/resource/whateverpath/metamodel2.genmodel"/>
</fragment>
Hope that helps,
Sebastian
Am 15.06.2009 11:23 Uhr, schrieb Durga Prasana Sahoo:
> Hello Sebastian
> Thanks.
> Durga
Previous Topic:Rich text styling in a Xtext-generated editor
Next Topic:Bug in codecompletion?
Current Time: Sat Jul 12 11:39:18 EDT 2025
Powered by FUDForum. Page generated in 0.05797 seconds
