Home » Eclipse Projects » DTP » JPA Catalog Explorer and JPQL Query Builder
JPA Catalog Explorer and JPQL Query Builder [message #50731] Wed, 08 October 2008 07:27 Go to next message
Originally posted by: philippeweber57.yahoo.fr
in the scope of my project I'm customizing the SQL Query Builder from
DTP to leverage select statement creation, I created a custom dtp
enablement project as input for the Query Builder and I intend to use
JPA inside the catalog provider. Getting far from simple Database/SQL...
I found that the work done on modelbase for SQL is really great, and I'm
wondering how it could serve (as basis or example) JPA and JPQL more
generally.
One idea would be to have a JPA Source Explorer similar to display JPA
catalogs provided by plug-ins, and a JPQL Editor with a QueryBuilder
with correct content assist read from JPA catalogs (bundled in plug-in).
I don't know if JPA could be used as the input of DTP defining a
enablement project, or if a fully new datatools.modelbase.jpql and
datatools.jpqltools would be needed.
Maybe the experts could light me up on these part.
In a short term, I'll anyway need to tweak the SQL Query Builder for my
needs, maybe up to the parser. But thinking generally, maybe a part of
all this could be reused.
Any comments are welcomed.
Philippe
Re: JPA Catalog Explorer and JPQL Query Builder [message #50926 is a reply to message #50731] Wed, 15 October 2008 20:39 Go to previous messageGo to next message
Can you describe how JPQL is similar or different from standard SQL?
Suggestions (and patches) on how to generalize the SQL Query Builder to
handle more SQL (or semi-SQL) dialects would be welcome.
Philippe Weber wrote:
> generally.
> Philippe
Re: JPA Catalog Explorer and JPQL Query Builder [message #50953 is a reply to message #50926] Thu, 16 October 2008 15:06 Go to previous message
Brian,
The main conceptual difference between JPQL and SQL is that JPQL queries
are defined against JPA entities (objects), as opposed to being directly
written against a database schema. When data needs to be stored or
retrieved from a relational database a JPA runtime will generally do this
on the back-end via SQL.
Take a look at this article for the basics on JPQL and how it relates to
SQL - http://www.oracle.com/technology/pub/articles/vasiliev-jpql. html
Neil
>> generally.
>> Regards,
>> Philippe
Re: JPA Catalog Explorer and JPQL Query Builder [message #593552 is a reply to message #50731] Wed, 15 October 2008 20:39 Go to previous message
> generally.
> Philippe
Re: JPA Catalog Explorer and JPQL Query Builder [message #593562 is a reply to message #50926] Thu, 16 October 2008 15:06 Go to previous message
Brian,
Neil
>> generally.
>> Regards,
>> Philippe
Previous Topic:Is org.eclipse.datatools.sqltools.parsers.sql.query.vendorExtension used ?
Next Topic:standalone sync plugin
Current Time: Sat Nov 08 07:17:36 EST 2025
Powered by FUDForum. Page generated in 0.03779 seconds
