Home » Eclipse Projects » Technology Project and PMC » Which is better plug-in development style as runtime classes specify
Which is better plug-in development style as runtime classes specify [message #50701] Fri, 28 March 2003 01:17 Go to next message
Originally posted by: narushima_to.ybb.ne.jp
Plug-ins need to specify how to load Eclipse runtime classes.
It is two way:
1) specify in ".classpath" file. e.g,
<classpathentry kind="var"
path="ECLIPSE_HOME/plugins/org.eclipse.ui_2.0.2/workbench.jar "/>
2)
Download eclipse runtime package from CVS. and specify in
".project" file.
In case (1), It is light weight. when developer installs eclipse
default install, no problem to create plug-in.
In case (2), It need to download sources from CVS. Developer can
programming and debugging in eclipse lastest version with plug-in
development.
(But, Plug-in depend on Eclipse Main branch that may be desirable
on XP practice "Continuous Integration")
Which is better development style?
Narushima Hironori mailto:narushima_to@ybb.ne.jp
Re: Which is better plug-in development style as runtime classes specify [message #50729 is a reply to message #50701] Fri, 28 March 2003 01:29 Go to previous messageGo to next message
Originally posted by: burner.zclipse.org
On Fri, 28 Mar 2003 15:17:10 +0900, Narushima Hironori wrote:
This question should go in the eclipse.tools newsgroups. However, to get
your question answered quickly...
> It is two way:
> 2)
> ".project" file.
3) Import external plugins. (File/import/external plug-ins and
fragments/don't extract source/select all/...) Then you can build your
plug-in against those binary plugins. This is probably the best way.
Use the eclipse wiki [http://eclipsewiki.swiki.net/] to find answers to
similar frequently asked questions.
mike
Re: Which is better plug-in development style as runtime classes specify [message #50927 is a reply to message #50701] Mon, 31 March 2003 10:23 Go to previous message
>It is two way:
>2)
>".project" file.
>development.
Both files may or may not be under (CVS) version control. They are used
for different purposes:
..project is owned by Platform core to manage the project meta data
(independent from Jdt).
..classpath is owned by JDT Core to manage the project's build path
HTH
Dani
Re: Which is better plug-in development style as runtime classes specify [message #592210 is a reply to message #50701] Fri, 28 March 2003 01:29 Go to previous message
> It is two way:
> 2)
> ".project" file.
mike
Re: Which is better plug-in development style as runtime classes specify [message #592292 is a reply to message #50701] Mon, 31 March 2003 10:23 Go to previous message
>It is two way:
>2)
>".project" file.
>development.
HTH
Dani
Previous Topic:complain about SWT on OSX
Next Topic:project structure
Current Time: Wed Nov 05 22:12:36 EST 2025
Powered by FUDForum. Page generated in 0.15503 seconds
