Home » Language IDEs » Java Development Tools (JDT) » How to implement a code editor with syntax colored
How to implement a code editor with syntax colored [message #50666] Thu, 05 June 2003 12:44 Go to next message
Originally posted by: li_ma.email.com
Hi there,
In my own project, I need to implement a script language editor with Java.
I would like to have a color-syntax editor for the script. Anyone can
point me where to learn the trick?
Thanks in advance!
-Li
Re: How to implement a code editor with syntax colored [message #51220 is a reply to message #50666] Fri, 06 June 2003 03:02 Go to previous messageGo to next message
Originally posted by: yves.somewhere.com
You can learn a lot from the javaeditor in the Eclipse examples.
Li wrote:
> Hi there,
> Thanks in advance!
> -Li
Re: How to implement a code editor with syntax colored [message #51246 is a reply to message #50666] Fri, 06 June 2003 03:10 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
If you download the examples there is a java editor example which shows you
how deal with syntax-coloring, code-completion and outline.
Also try to New-->Plugin project-->...-->Plugin with an editor. This wizard
creates source code for a basic xml-editor with syntax-highlighting.
If you want to get only syntax-highlighting for that script language (and
nothing else) I can recommend you to download the color editor plugin from
http://gstaff.org/colorEditor/
It does syntax-highlighting for a number of languages and I think you can
create new ones simply editing the xml files in
plugins\cbg.editor_0.2.8\modes.
HTH,
Csaba
"Li" <li_ma@email.com> wrote in message news:bbns1m$bin$1@rogue.oti.com...
> Hi there,
> Thanks in advance!
> -Li
Previous Topic:JRun Plugin Alternative?
Next Topic:incremental project builder not compiling
Current Time: Sat Oct 25 03:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
