Home » Language IDEs » Java Development Tools (JDT) » external jar
external jar [message #50639] Thu, 05 June 2003 12:44 Go to next message
Originally posted by: jzhou.persistence.com
Does anyone know if there is a way to programatically load classes in an
external jar using the current project's classloader at runtime?
Jie
Re: external jar [message #50801 is a reply to message #50639] Thu, 05 June 2003 14:02 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Go to the popup menu on the project and select properties.
From there goto Java Build Path, go to the Libraries page,
go to "Add External Jars..." button and select your jar.
Rich
Re: external jar [message #51350 is a reply to message #50801] Fri, 06 June 2003 04:52 Go to previous message
Hi there,
Well he/she talked about 'at runtime'. Maybe there is
some dynamic behaviour wished.
Well there is another way (I know worked for Applets).
As far as I remember, you can load the jar as a resource.
Then you can use the classes by getting the Class instance
by name (forName i think) and get instances by
create/get/newInstance (not sure which one and to lazy
to look at;)
Hope that works for applications too.
Bye
Martin
PS: If you gonna debug some dynamic code just point
a source to it. (debugger dialog i think)
Previous Topic:incremental project builder not compiling
Next Topic:Closing bracket
Current Time: Thu Jul 31 02:33:36 EDT 2025
Powered by FUDForum. Page generated in 0.27138 seconds
