Home » Eclipse Projects » Equinox » org.eclipse.osgi.framework.console not accessible + order of starting bundles
org.eclipse.osgi.framework.console not accessible + order of starting bundles [message #50638] Sun, 16 October 2005 11:06 Go to next message
Originally posted by: mslocins.gmail.com
in
http://www.eclipse.org/newsportal/article.php?id=1045&gr oup=eclipse.technology.equinox#1045
I found that org.eclipse.osgi.framework.console.CommandProvider can be
implemented and registered as a service in order to extend console with
additional commands. There is a discussion if
org.eclipse.osgi.framework.console should be exported or not - however in
Eclipse 3.2 I noticed it is exported already. I added such dependency to
org.eclipse.osgi.framework.console in my plugin, however I'm getting
ClassNotFoundException when I try to register my service implementing that
interface. My manifest file contains:
Import-Package: org.eclipse.osgi.framework.console,
org.osgi.framework;version="1.3.0"
Do you know solution for that issue?
Other question is order of installing and starting bundles. On
http://eclipse.org/equinox/quickstart.html there is following information:
"Where config.ini is a Java properties file that contains the following
line. Note that the osgi.bundles property is quite powerful. See the doc
for details.
osgi.bundles=B1:start, B2:start
It doesn't work for me - I had to browse through Eclipse installation
folder and add such line in my config.ini:
osgi.bundles=B1@2:start, B2@3:start
I thought @2, @3 describes order of installing/starting of bundles, but
unfortunatelly it doesn't work as I expected. Could someone tell me what
is role of those numbers? Additional question is - how to define order of
starting bundles?
Michal
Re: org.eclipse.osgi.framework.console not accessible + order of starting bundle [message #50665 is a reply to message #50638] Sun, 16 October 2005 14:22 Go to previous messageGo to next message
Sorry for previous mail :-/ Everything works as I expected, root of my
issues were symlinks in filesystem (ext3@linux), I had following directory
structure with two bundles (test and srv):
configuration
config.ini
test -> /path/to/real/test
srv -> /path/to/real/srv
org.eclipse.osgi.jar
it didn't work well so don't try it at home :-] After starting using real
directories, everything runs smoothly now.
Michal
Re: org.eclipse.osgi.framework.console not accessible + order of starting bundles [message #50919 is a reply to message #50638] Wed, 19 October 2005 21:10 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
the numbers are start levels. Bundles are installed optionally marked as
"startable" in hte order they are listed. Note that they are not acutally
started (i.e., their start methods called) until the system's start level
reaches the level at which they reside. See
http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/reference/misc/runtime-options.html
Jeff
"Michal" <mslocins@gmail.com> wrote in message
news:4600a4ff974c63c439e62dfc484c90c5$1@www.eclipse.org...
> in
> for details.
> starting bundles?
> Michal
Previous Topic:shared install and varying configurations
Next Topic:Equinox OSGi VS Spring ?
Current Time: Mon Nov 17 15:15:28 EST 2025
Powered by FUDForum. Page generated in 0.03670 seconds
