Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EJB3 annotations
EJB3 annotations [message #50607] Fri, 15 September 2006 02:09 Go to next message
Originally posted by: xkamlesh.yahoo.com
How do I get ASSIGNED attribute for ID generator class like
<id name="id" type="java.lang.String" column="'id'">
<generator class="assigned">
</generator>
</id>
I use EJB3 Column annotation. It works for AUTO generator but for ASSIGNED
it
throws the following exception.
SEVERE: Error setting feature 'strategy' [Cannot convert 'ASSIGNED' to
'GenerationType' type] annotation: http://ejb.elver.org/GeneratedValue
Re: EJB3 annotations [message #50631 is a reply to message #50607] Fri, 15 September 2006 03:08 Go to previous message
Kamlesh,
Afaik assigned is the default strategy if no generator is specified (for hibernate).
Assigned is a hibernate specific value which is not part of the ejb3 spec.
In the latest teneo version you can specify hibernate specific generators:
If you want to use hibernate specific generators then you should use the GenericGenerator annotation
(for more info see the Hibernate Annotation Extensions).
As an example this annotation should be placed at package level in an eannotation (using the source:
teneo.jpa):
@GenericGenerator(name="hibseq", strategy = "hilo",
parameters = {
@Parameter(name="table", value = "hilo_table"),
@Parameter(name="column", value="the_hilo_column")
and then in the id field this annotation can be used (specified in an eannotation with source
teneo.jpa):
@Id @GeneratedValue(generator="hibseq")
Instead of eannotations you can also specify the annotations in a separate xml file.
gr. Martin
> </generator>
> </id>
> ASSIGNED it
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: EJB3 annotations [message #591164 is a reply to message #50607] Fri, 15 September 2006 03:08 Go to previous message
Kamlesh,
teneo.jpa):
parameters = {
teneo.jpa):
gr. Martin
> </generator>
> </id>
> ASSIGNED it
The Netherlands
Previous Topic:EJB3 annotations
Next Topic:OCL help needed
Current Time: Wed Nov 12 20:45:18 EST 2025
Powered by FUDForum. Page generated in 0.03427 seconds
