Home » Archived » Test and Performance Tools Platform (TPTP) » Classpath problem while profiling plug-in
Classpath problem while profiling plug-in [message #50576] Sat, 14 January 2006 06:38 Go to next message
Originally posted by: lars.nospam.ohlen.dontspam.se
I have created a custom specific Ant plug-in. It works perfectly both when
installed as a plug-in and during development running in the runtime
workbench.
But when I'm using TPTP for profiling (memory, executing etc) Ant gets
classloading problems! A very generic error message is displayed saying
Could not find one or more classes. Please check the Ant classpath.
I know that my Ant plug-in module uses some internal eclipse Ant classes,
but I would excpect that the classpath should be the same when executing and
profiling.
After some debugging I have found that the class missing is
org.eclipse.ant.internal.core.ant.InternalAntRunner (located in the
antsupportlib.jar). I have added
this jar file as a runtime required library and I have also changed the Ant
classpath in the runtime workbench prefs. With no luck.
I have checked the source code for the Ant plug-ins and perhaps the problem
is the custom classloading that occurs while interacting with the Apache
implemenation.
Any ideas / help appreciated.
Using Eclipse 3.1.1, TPTP 4.1,Windows XP Pro
BR
Lars
Re: Classpath problem while profiling plug-in [message #51342 is a reply to message #50576] Mon, 23 January 2006 20:31 Go to previous messageGo to next message
Lars,
Your classloading maybe java related. What version of java are you
using?
Guru
Lars wrote:
> workbench.
> profiling.
> implemenation.
> BR
> Lars
Re: Classpath problem while profiling plug-in [message #52881 is a reply to message #51342] Sun, 05 February 2006 05:15 Go to previous message
I'm using Sun 1.4.2_06
/Lars
"Guru Nagarajan" <guru.nagarajan@intel.com> skrev i meddelandet
news:43D5836B.7030803@intel.com...
> Lars,
> using?
> Guru
> Lars wrote:
>> when installed as a plug-in and during development running in the runtime
>> workbench.
>> and profiling.
>> Ant classpath in the runtime workbench prefs. With no luck.
>> problem is the custom classloading that occurs while interacting with the
>> Apache implemenation.
>> BR
>> Lars
Previous Topic:Eclipse TPTP Strengthens Integration with BIRT and WTP
Next Topic:Problems with UML2 diagrams
Current Time: Mon Jul 21 21:12:30 EDT 2025
Powered by FUDForum. Page generated in 0.03231 seconds
