Home » Eclipse Projects » GEF » [jdt-ui-dev] Pre-reqs are not exported
[jdt-ui-dev] Pre-reqs are not exported [message #50510] |
Thu, 19 December 2002 10:45  |
Randy,
Is/will your plugin available publicly? Can I re-use your layout algorithm
for my plugins?
Does you layout algorithm consider the node size when it calculates the
positions of each node? Can it support nodes with different size? From the
attached diagrams that you provided, the edge automatically bends. Does it
use some kind of connection router to achieve that? Can I use that
connection router in my plugins also?
Thank you.
-----Original Message-----
Sent: Wednesday, December 18, 2002 3:23 PM
To: jdt-ui-dev@eclipse.org
Subject: Re: [jdt-ui-dev] Pre-reqs are not exported
Here is a graph of the plugins I have loaded in my workspace (jdt.ui, GEF,
and dependencies). It is not all of Eclipse. The layout algorithm isn't
finished yet, but it does a pretty good job so far.
There are two versions attachments. In one graph, all required plugins are
"exported", reducing the number of edges. In the second attachment, *every*
requirement is shown.
(Sorry if this post is a duplicate. I think my first attempt was rejected
due to address problems
Re: [jdt-ui-dev] Pre-reqs are not exported [message #50538 is a reply to message #50510] |
Thu, 19 December 2002 11:08   |
Originally posted by: hudsonr.us.eye-bee-em.com
[This thread is in reference to the attached Image that was sent to another
mailing list]
Hal,
I would like to eventually release this algorithm. The algorithm places
both nodes and connections at the same time, and nodes can be any size.
There is more work to be done on the algorithm, and on other stuff in GEF.
This was a proof of concept, and I need to get a feel for the demand. I
need to switch focus back to the 2.1 committed items for now.
The code is not integrated in any way with draw2d/GEF. I created a model of
the graph, ran the code, and then generated XYLayout constraints based on
the results. This is great for a one-time layout, but tighter integration
would be nice.
"Hal" <otaconss2@hotmail.com> wrote in message
news:atsp41$eud$1@rogue.oti.com...
> Randy,
> for my plugins?
> Thank you.
> From: Randy Hudson [mailto:hudsonr@us.ibm.com]
are
*every*
Re: [jdt-ui-dev] Pre-reqs are not exported [message #50594 is a reply to message #50538] |
Thu, 19 December 2002 12:22   |
Thanks.
So your algorithm automatically bends connections so that they won't overlap
with any nodes? Is it possible to package that part of function as a
Connection Router so that I can use that separate in my GEF plugins?
Thank you.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:atsqj6$g93$1@rogue.oti.com...
another
> mailing list]
> Hal,
of
> would be nice.
> > Randy,
algorithm
> > for my plugins?
the
it
> > Thank you.
GEF,
> are
> *every*
rejected
Re: [jdt-ui-dev] Pre-reqs are not exported [message #50733 is a reply to message #50538] |
Sun, 22 December 2002 18:29  |
Thanks Randy,
This looks very cool!
I would like to know how the algorithm automatically bends connection to
avoid overlapping with figure in the diagram.
another
> mailing list]
> Hal,
of
> would be nice.
> > Randy,
algorithm
> > for my plugins?
the
it
> > Thank you.
GEF,
> are
> *every*
rejected
Current Time: Tue Jul 15 02:49:18 EDT 2025
Powered by FUDForum. Page generated in 0.31478 seconds
