Home » Language IDEs » C / C++ IDE (CDT) » Is there a patch for 24648?
Is there a patch for 24648? [message #50478] Mon, 18 November 2002 10:37 Go to next message
Originally posted by: ed.burnette.no.spam.sas.com
I know that 2.0.1 is the only officially supported version with CDT. However
I'd like to be able to run the M3 version anyway :). So is there a patch for
the typing backwards problem (24648) that would let us run M3 with CDT? If
not, then if someone could point me at what the problem is maybe I could
create one for my own use. (I searched the group and found a mention of such
a patch but then a followup that said it had been removed, but didn't find
the patch itself). Thanks.
Re: Is there a patch for 24648? [message #50618 is a reply to message #50478] Mon, 18 November 2002 15:59 Go to previous message
"Ed Burnette" <ed.burnette@no.spam.sas.com> wrote in message
news:aravaf$gjc$1@rogue.oti.com...
However
for
such
There is a fix in CVS for this problem, but it has been rolled back until we
move forward and try to find a compatible solution if posible.
You could look at the file that has the fix in CVS, if you wanted to do
something in parallel
The file affected is
/home/tools/org.eclipse.cdt.ui/src/org/eclipse/cdt/internal/ ui/text/Buffered
DocumentScanner.java
Please note that there may be other issues that you run into, since we are
not currently supporting 2.1 builds of Eclipse.
-Judy
Previous Topic:Keypad cursor keys
Next Topic:CoreModel.create() unusable?
Current Time: Sun Aug 31 03:28:10 EDT 2025
Powered by FUDForum. Page generated in 0.05970 seconds
