Home » Archived » XML Schema Definition (XSD) » [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol://h
[newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol://h [message #50442] Wed, 18 August 2004 08:37 Go to next message
Originally posted by: mehow.remove.neurosoft.net
I encounter problem creating a schema model for my schema. I get the
following exception:
found. (myprotocol://host/path, 2, -1)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:1363)
Note that I'm using my own protocol here, but it doesn't seem to be a
problem, since when I was trying to debug it, the parser was invoking
startElement for the schema elements (so the schema has been loaded).
Instead it seems like the schema element cannot be recognized. On the
other the same schema is read successfully from disk using file://
protocol - I don't see the difference.
Here is the schema:
<xs:schema elementFormDefault="qualified"
attributeFormDefault="unqualified"
xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:element name="root"/>
</xs:schema>
Does anybody knows what can cause this problem?
If you need more information to help me, please tell me.
Michal Tkacz
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #50470 is a reply to message #50442] Wed, 18 August 2004 09:46 Go to previous messageGo to next message
The problem was with the URI: it didn't end with ".xsd". Apparently EMF
uses the extension of the URI to recognize the type of the document.
It also uses the name of the protocol to find this information, but
obviously it didn't know anything about my protocol. I guess there must
be a way to register it somehow - can anyone help me with that?
Michal Tkacz
Michal Tkacz napisał(a):
> at
> Here is the schema:
> </xs:schema>
> Michal Tkacz
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #50497 is a reply to message #50470] Wed, 18 August 2004 10:11 Go to previous messageGo to next message
--------------060202090101070702020304
Content-Type: text/plain; charset=UTF-8; format=flowed
Michal,
Maybe it would help if you show what you tried.
If you have a URL that you know is a schema but isn't one that EMF will
recognize as one, you can use a technique like this to force an
XSDResourceImpl to be created:
InputStream inputStream =
resourceSet.getURIConverter().createInputStream(uri);
resolvedResource = resourceSet.createResource(URI.createURI("*.xsd"));
resolvedResource.setURI(uri);
resolvedResource.load(inputStream, resourceSet.getLoadOptions());
> EMF uses the extension of the URI to recognize the type of the document.
> must be a way to register it somehow - can anyone help me with that?
> Michal Tkacz
>> at
>> Here is the schema:
>> <?xml version="1.0" encoding="UTF-8"?>
>> </xs:schema>
>> Michal Tkacz
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Michal,<br>
<br>
Maybe it would help if you show what you tried.   <br>
<br>
XSDResourceImpl to be created:<br>
<blockquote>InputStream inputStream =
resourceSet.getURIConverter().createInputStream(uri);<br>
resolvedResource = resourceSet.createResource(URI.createURI("*.xsd"));<br>
resolvedResource.setURI(uri);<br>
resolvedResource.load(inputStream, resourceSet.getLoadOptions());<br>
</blockquote>
<br>
<br>
Michal Tkacz wrote:<br>
<blockquote cite="midcfvmdd$uc8$1@eclipse.org" type="cite">The problem
was with the URI: it didn't end with ".xsd". Apparently EMF uses the
<br>
<br>
<br>
<br>
Michal Tkacz
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
other the same schema is read successfully from disk using <a class="moz-txt-link-freetext" href="file://">file://</a>
<br>
<br>
Here is the schema:
<br>
<br>
&lt;?xml version="1.0" encoding="UTF-8"?&gt;
<br>
&lt;xs:schema elementFormDefault="qualified"
xmlns:xs=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>&gt;
<br>
    &lt;xs:element name="root"/&gt;
<br>
&lt;/xs:schema&gt;
<br>
<br>
<br>
<br>
<br>
Michal Tkacz
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------060202090101070702020304--
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #50525 is a reply to message #50497] Wed, 18 August 2004 14:18 Go to previous messageGo to next message
Thanks Ed,
Basically, I wanted to be able to browse schemas that could possibly include or
import one another and that are stored neither in a filesystem nor on a web
server (but in a database).
Since my URIs did not originally end with ".xsd" I was getting the error while
trying to load the main schema (I used ResourceSet.getResource(URI)). Once I
debugged the code I found the reason and appended ".xsd" to the URIs.
Actually, I just realized that once the original schema is loaded, the
imported/included ones would probably be treated as schemas, regardless of
whether their URIs end with ".xsd". If this is the case, I could probably use
your solution to load the main schema. I haven't checked that though.
What I thought is that there could be some mechanism that let you change the
list of mappings protocol -> resource factory (and extension -> resource
factory) that EMF is aware of. Anyway I will have to read some documentation on
EMF since I only read one article on XSD so far.
Again, thanks for help!
Michal
Ed Merks napisał(a):
> Michal,
>> Michal Tkacz
>>> Hi,
>>> at
>>> Here is the schema:
>>> </xs:schema>
>>> Michal Tkacz
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #50554 is a reply to message #50525] Wed, 18 August 2004 14:59 Go to previous message
Michal,
As you suspected, a resource set has a resource factory registry that
will let you tailor how URIs are mapped to resource factories, so
registering the extension "*" for XSDResourceFactoryImpl should make it
the default for all URIs. The code snippet I showed you is actually
from the code that loads an import or include, so as you deduced, they
don't care about the extension and ensure that the URI is treated as a
schema.
Michal Tkacz wrote:
> Thanks Ed,
> include or import one another and that are stored neither in a
> filesystem nor on a web server (but in a database).
> error while trying to load the main schema (I used
> ResourceSet.getResource(URI)). Once I debugged the code I found the
> regardless of whether their URIs end with ".xsd". If this is the case,
> I could probably use your solution to load the main schema. I haven't
> change the list of mappings protocol -> resource factory (and
> extension -> resource factory) that EMF is aware of. Anyway I will
> have to read some documentation on EMF since I only read one article
> on XSD so far.
> Michal
>> Michal,
>> will recognize as one, you can use a technique like this to force an
>> resolvedResource =
>>> document.
>>> Michal Tkacz
>>>> Hi,
>>>> the following exception:
>>>> not found. (myprotocol://host/path, 2, -1)
>>>> at
>>>> a problem, since when I was trying to debug it, the parser was
>>>> invoking startElement for the schema elements (so the schema has
>>>> been loaded). Instead it seems like the schema element cannot be
>>>> recognized. On the other the same schema is read successfully from
>>>> disk using file:// protocol - I don't see the difference.
>>>> Here is the schema:
>>>> </xs:schema>
>>>> Michal Tkacz
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #590267 is a reply to message #50442] Wed, 18 August 2004 09:46 Go to previous message
Michal Tkacz
> at
> Here is the schema:
> </xs:schema>
> Michal Tkacz
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #590288 is a reply to message #50470] Wed, 18 August 2004 10:11 Go to previous message
Michal,
> Michal Tkacz
>> at
>> Here is the schema:
>> </xs:schema>
>> Michal Tkacz
<html>
<head>
<title></title>
</head>
Michal,<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
Michal Tkacz
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Here is the schema:
<br>
<br>
<br>
<br>
<br>
&lt;/xs:schema&gt;
<br>
<br>
<br>
<br>
<br>
Michal Tkacz
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #590305 is a reply to message #50497] Wed, 18 August 2004 14:18 Go to previous message
Thanks Ed,
Michal
> Michal,
>> Michal Tkacz
>>> Hi,
>>> at
>>> Here is the schema:
>>> </xs:schema>
>>> Michal Tkacz
Re: [newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol [message #590322 is a reply to message #50525] Wed, 18 August 2004 14:59 Go to previous message
Michal,
schema.
Michal Tkacz wrote:
> Thanks Ed,
> on XSD so far.
> Michal
>> Michal,
>> resolvedResource =
>>> document.
>>> Michal Tkacz
>>>> Hi,
>>>> at
>>>> Here is the schema:
>>>> </xs:schema>
>>>> Michal Tkacz
Previous Topic:[newbie] org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'schema' not found. (myprotocol://h
Next Topic:How to find "root" element in a schema. Check if an element is referenced
Current Time: Sat Jul 12 19:37:50 EDT 2025
Powered by FUDForum. Page generated in 0.04491 seconds
