Home » Eclipse Projects » Equinox » shared install and varying configurations
shared install and varying configurations [message #50414] Tue, 11 October 2005 10:04 Go to next message
I am using a minimal Eclipse configuration (startup.jar,
org.eclipse.update.configurator, org.eclipse.core.runtime,
org.eclipse.core.runtime). I have a single install (osgi.install.area)
with multiple configuration locations (set via osgi.configuration.area
property). Currently each configuration location is empty (a platform.xml
is not defined), thus all installed bundles can start. I want add some
bundles that are installed in a different location to one of the
configurations.
Looking at the configuration support, it appears I have to define a link to
the new bundles. Then define a platform.xml for each configuration and
include the linked bundles only in the configuration that they are needed.
Is that correct?
Is there a way to include the new bundles with one of the configurations
without having to define a platform.xml for all of them?
Regards, Jim V.O.
Re: shared install and varying configurations [message #50499 is a reply to message #50414] Thu, 13 October 2005 03:43 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Jim,
Great question. The short answer is no, you have to craft a configuration.
Using update.configurator creates a configuration (if one does not exist),
based on the global information that "discovered" in the Eclipse install
area. The update.configurator is promiscuous in this sense.
If you want to have some configurations that include a more limited set of
plugins (and you are using update.configurator) you need to construct a
platform.xml that points the the plugins you want.
Eclipse could use a configuration editor but currently this is largely a
hand rolling effort for you. There is some doc on the platform.xml format
in the help
( http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/reference
/misc/update_platform_xml.html)
Jeff
"Jim VanOosten" <jimvo@us.ibm.com> wrote in message
news:diggpi$emk$1@news.eclipse.org...
platform.xml
> configurations.
to
> Is that correct?
> Regards, Jim V.O.
Previous Topic:Plugin hot deploy
Next Topic:org.eclipse.osgi.framework.console not accessible + order of starting bundles
Current Time: Tue Jul 22 01:36:09 EDT 2025
Powered by FUDForum. Page generated in 0.04414 seconds
