Home » Language IDEs » Java Development Tools (JDT) » Text Editor - How it works
Text Editor - How it works [message #50391] Thu, 05 June 2003 10:25 Go to next message
I need to know how the text editor plug-in is able to act as default editor
for the file that has no editor associated with it.
We can open any file with the text editor using "open with" options in the
popup menu but the text editor won't be the default editor for the files
that has some other editor assigned as default editor.
What is the technical procedure that goes with text editor. If text editor
plug-in is able to it then what is the secret formula that they are
following to do this.
Please explain in details.
MorPheus
Re: Text Editor - How it works [message #51563 is a reply to message #50391] Fri, 06 June 2003 08:11 Go to previous messageGo to next message
For the editor I wrote, the magic was in the plugin.xml:
<extension point="org.eclipse.ui.editors">
<editor
name="Wiki Editor"
default="true"
icon="icons/eclipse.gif"
extensions="wiki"
contributorClass="org.eclipse.ui.texteditor.BasicTextEditorActionContributor "
class="com.teaminabox.eclipse.wiki.editors.WikiEditor"
id="com.teaminabox.eclipse.wiki.editors.WikiEditor">
</editor>
</extension>
The extensions attribute did the business.
Channing
Re: Text Editor - How it works [message #52364 is a reply to message #51563] Sat, 07 June 2003 10:45 Go to previous messageGo to next message
well hope u misunderstand my problem (may be I didn't put in correct
way).I need my editor to act like default editor for all the files
irrespective of file extensions, provided, if that file doesn't have any
editor associated with it.Say for example text editor .Text editor will be a
default editor for all the files that don't have editor associated with
it.If the some other editor is associated for a particular file,then the
file can be still opened using text editor by using open with menu.How to
achieve this kind of functionality.
MorPheus.
"Channing Walton" <channingwalton@mac.com> wrote in message
news:bbq0cr$dg$1@rogue.oti.com...
editor
> <editor
> name="Wiki Editor"
> default="true"
> extensions="wiki"
> </editor>
> </extension>
> Channing
Re: Text Editor - How it works [message #52727 is a reply to message #52364] Sun, 08 June 2003 12:08 Go to previous messageGo to next message
MorPheus wrote:
Sorry Morpheus, I did misunderstand - no idea how to do this.
Channing
Re: Text Editor - How it works [message #52916 is a reply to message #52364] Mon, 09 June 2003 00:37 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
"MorPheus" <rgurupackiam@selectica.com> wrote in message
news:bbstpe$nmr$1@rogue.oti.com...
a
You can't do this reliably. Even if you specify extension as *.* (if this
even works), whenever there are two editors that want to be the default
editor for the same extension, Eclipse arbitrarily picks one. No way I know
of to make sure you're the one.
(If there were a way to do this, I wouldn't install your plugin. Is it just
an ego thing, or what? ;-)
Bob
Re: Text Editor - How it works [message #53146 is a reply to message #52916] Mon, 09 June 2003 07:34 Go to previous messageGo to next message
Then How does the text editor achieve this functionality?
Morpheus
"Bob Foster" <bob@objfac.com> wrote in message
news:bc126o$m0d$1@rogue.oti.com...
> > Hi,
be
> a
to
know
just
> Bob
Re: Text Editor - How it works [message #54086 is a reply to message #53146] Wed, 11 June 2003 03:34 Go to previous message
news:bc1rb7$4lv$1@rogue.oti.com...
It is hard-coded in EditorRegistry getDefaultEditor() to
IWorkbenchConstants.DEFAULT_EDITOR_ID which is set to
"org.eclipse.ui.DefaultTextEditor" which is registered by the org.eclipse.ui
plugin.
(I had to read the source to get this answer. I highly recommend learning
how to do this for yourself.)
Bob
> Morpheus
> > > Hi,
correct
any
will
> be
> > a
with
the
> to
this
> know
> just
> > Bob
Previous Topic:Problem with Eclipse, Tomcat Plug and Apache Commons Logging w/ Log4J
Next Topic:JBuilder to Eclipse migration
Current Time: Tue Nov 11 19:34:11 EST 2025
Powered by FUDForum. Page generated in 0.05054 seconds
