Home » Eclipse Projects » Eclipse Platform » Linux non root user
Linux non root user [message #50290] Tue, 27 May 2003 14:12 Go to next message
I installed Eclipse 2.1 on a SuSe 8.2 load. Eclipse will run under
root but fails to start as a non-root user. What do I have to do to get
Eclipse to run under a non-root user. Thanks
Re: Linux non root user [message #50487 is a reply to message #50290] Tue, 27 May 2003 15:40 Go to previous message
Originally posted by: chaves.inf.ufsc.br_no-spam
Eclipse by default creates its workspace in the current directory. If you
want to avoid that (because you don't have rights to write to the Eclipse
directory), you can use the -data command line option:
/eclipse -data /home/my_home_dir/workspace
More info see:
http://dev.eclipse.org/help21/topic/org.eclipse.platform.doc .user/tasks/running_eclipse.htm
Previous Topic:KeyBinding - is this correct?
Next Topic:Link with .NET component
Current Time: Tue Sep 09 18:40:38 EDT 2025
Powered by FUDForum. Page generated in 0.49485 seconds
