| [ATL] Problems with TupleType [message #50270] |
Mon, 02 July 2007 04:44  |
Originally posted by: francopinchetti.yahoo.it
Hello everybody,
I'm writing an ATL transformation in which I'm using the TupleType data
type. I want to create a Sequence of TupleType(mpn : String, slot : Integer,
freeslot : Integer). I have a called rule like this:
rule SecondFunction(mcs : Sequence(TupleType(mpn : String, slot : Integer,
freeslot : Integer))) {
do {
for (cp in .) {
cp.multiplicityCoupleSerializzation().toString().concat('
debug row 1').println(); -- debug row n. 1
mcs->append(cp.multiplicityCoupleSerializzation());
mcs.toString().concat(' debug row 2').println(); -- debug row
n. 2
And that's the helper multiplicityCoupleSerializzation():
helper context ModelFragmentMM!Couple def :
multiplicityCoupleSerializzation() : TupleType(mpn : String, slot : Integer,
freeslot : Integer) =
if (.) then
let sl : Integer = . in
Tuple{mpn = self.propName, slot = sl, freeslot = sl}
else
Tuple{}
endif
When I lunch the transformation the console says:
Tuple {freeslot = 1, slot = 1, mpn = '.'} debug row 1
Sequence {} debug row 2
Why the append operation on mcs don't work? And why the Tuple returned by
multiplicityCoupleSerializzation() has a different component order compared
to the helper declaration?
Thank you very much
Franco
| Re: [ATL] Problems with TupleType [message #50300 is a reply to message #50270] |
Mon, 02 July 2007 05:08   |
Hi Franco,
Franco wrote:
> Hello everybody,
> do {
> for (cp in .) {
> n. 2
> if (.) then
> else
> Tuple{}
> endif
The append operation has a return type (mcs <- mcs->append(...)).
And the Tuple type is not ordered.
See the ATL User Manual for more details on append() operation and Tuple
data type.
> Thank you very much
> Franco
Éric Vépa
SODIUS
6, rue de la Cornouaille - BP 91941
44319 Nantes, France
Email: evepa@sodius.com
www.mdworkbench.com
Draw more value from your models
FUDForum. Page generated in 0.03938 seconds
