Home » Archived » BIRT » Parameter in "in" SQL clause
Parameter in "in" SQL clause [message #50153] Thu, 23 June 2005 01:37 Go to next message
Originally posted by: shiffer_david.caramail.com
Is it possible to use a parameter in a "in" SQL clause, indeed i want to
do the following:
select * from table where id in ( ? )
The parameter should contains a string value like '1,2,3,4' but it doesn't
work, only one of these values is taken.
Anybody tried to use a parameter in this way?
Re: Parameter in "in" SQL clause [message #50334 is a reply to message #50153] Thu, 23 June 2005 05:16 Go to previous message
Originally posted by: none.none.com
Look for the thread of June 15th in this newsgroup with the subject: How do
I use multiple parameters in BITR?
David
"shiffer_david" <shiffer_david@caramail.com> wrote in message
news:ace57c5bccfe9a801bdfc247f3c0d842$1@www.eclipse.org...
> do the following:
Previous Topic:Missing
Next Topic:errors with flat file
Current Time: Mon Oct 20 19:02:22 EDT 2025
Powered by FUDForum. Page generated in 0.36648 seconds
