| xtext generator fails when calling from maven [message #50085] | Thu, 11 June 2009 08:44  |  |
| Eclipse User  |  |  |  |  | Hi,
 Im trying to mavenize my xtext project with the fornax plugin. I run in
 difficulties with a hierarchical module and directory layout. I have a
 parent module and in the parent module are submodules which represent the
 xtext and the xtext.ui project. When I build only the xtext project
 everything works fine. But when starting from the parent project it fails
 when reading the grammar files. But the grammar file is correctly
 generated!?!
 2219 [main] INFO ipse.xtext.generator.LanguageConfig  generating
 infrastructure for com.XXX.XXX.metamodel.type.Type with fragments :
 ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment,
 EcoreGeneratorFragment, ParseTreeConstructorFragment,
 ResourceFactoryFragment, DelegatingGeneratorFragment,
 JavaValidatorFragment, JavaScopingFragment, FormatterFragment,
 LabelProviderFragment, TransformerFragment,
 OutlineNodeAdapterFactoryFragment, JavaBasedContentAssistFragment,
 error(7): cannot find or open file:
 ../metamodel.type/src-gen/com/XXX/XXX/metamodel/type/parser/ antlr/internal/InternalType.g
 I have no clue what the exact meaning of the "pathRtProject" parameter is.
 Is this a relative path? How to put an absolute path there? At which point
 of the code is the path to the grammar file specified? Any ideas how to
 solve this?
 Christoph
FUDForum. Page generated in 0.04291 seconds
