Home » Language IDEs » AspectJ » Compile Error with "... implements ...<E>"
Compile Error with "... implements ...<E>" [message #50070] Mon, 21 March 2005 13:05 Go to next message
Originally posted by: rstoner.allstontrading.com
I'm running Eclipse 3.1M5a on a WinXP machine, using ADJT
1.2.0.20050308091611.
When trying to compile the class:
import java.util.Iterator;
public class Tiger implements Iterable<Object> {
public Iterator<Object> iterator() {
return null;
or
public class Tiger<E extends Object> implements Iterable<Object> {
return null;
I get the following error:
Internal compiler error
org.aspectj.org.eclipse.jdt.internal.compiler.lookup.ClassSc ope.detectHierarchyCycle(ClassScope.java:945)
org.aspectj.org.eclipse.jdt.internal.compiler.ast.Parameteri zedSingleTypeReference.internalResolveType(ParameterizedSing leTypeReference.java:143)
org.aspectj.org.eclipse.jdt.internal.compiler.ast.Parameteri zedSingleTypeReference.resolveType(ParameterizedSingleTypeRe ference.java:208)
org.aspectj.org.eclipse.jdt.internal.compiler.ast.TypeRefere nce.resolveSuperType(TypeReference.java:112)
org.aspectj.org.eclipse.jdt.internal.compiler.lookup.ClassSc ope.findSupertype(ClassScope.java:1092)
org.aspectj.org.eclipse.jdt.internal.compiler.lookup.ClassSc ope.connectSuperInterfaces(ClassScope.java:827)
org.aspectj.org.eclipse.jdt.internal.compiler.lookup.ClassSc ope.connectTypeHierarchy(ClassScope.java:885)
org.aspectj.org.eclipse.jdt.internal.compiler.lookup.Compila tionUnitScope.connectTypeHierarchy(CompilationUnitScope.java :249)
org.aspectj.ajdt.internal.compiler.lookup.AjLookupEnvironmen t.completeTypeBindings(AjLookupEnvironment.java:91)
org.aspectj.org.eclipse.jdt.internal.compiler.Compiler.begin ToCompile(Compiler.java:331)
org.aspectj.org.eclipse.jdt.internal.compiler.Compiler.compi le(Compiler.java:348)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.perfor mCompilation(AjBuildManager.java:682)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.doBuil d(AjBuildManager.java:168)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.doBuil d(AjBuildManager.java:128)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.increm entalBuild(AjBuildManager.java:109)
org.aspectj.ajde.internal.CompilerAdapter.compile(CompilerAd apter.java:117)
org.aspectj.ajde.internal.AspectJBuildManager$CompilerThread .run(AspectJBuildManager.java:165)
Changing the class to:
public class Tiger<E> implements Iterable<E> {
public Iterator<E> iterator() {
return null;
or
public class Tiger implements Iterable {
return null;
compiles fine.
Has anyone run into this before?
Ryan
Re: Compile Error with "... implements ...<E>" [message #50106 is a reply to message #50070] Mon, 21 March 2005 13:07 Go to previous message
I forgot to mention, I'm using Sun's 1.5.0_01 JDK.
Re: Compile Error with "... implements ...<E>" [message #587543 is a reply to message #50070] Mon, 21 March 2005 13:07 Go to previous message
Previous Topic:Compile Error with "... implements ...<E>"
Next Topic:where is aspectjtools.jar?
Current Time: Tue Jul 22 09:01:52 EDT 2025
Powered by FUDForum. Page generated in 0.36034 seconds
