XDoclet dies on stack overflow [message #50062] |
Sat, 09 April 2005 22:54  |
Originally posted by: alex.gestalt.com
I have an EJB project that depends on a number of other projects
containing variuous classes. Experimentally I found, that when these other
projects have mutual dependencies, such that project B must be placed into
project A's build path, and project A must be listed in the build path of
B, any attempt to create the XDoclet configuration for the EJB project, or
to run XDoclet, results in the java.lang.StackOverflowError (see the error
log below):
!ENTRY org.eclipse.ui 4 4 Apr 09, 2005 18:31:34.185
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Apr 09, 2005 18:31:34.185
!MESSAGE java.lang.StackOverflowError
!STACK 0
at java.util.HashMap.hash(HashMap.java:257)
at java.util.HashMap.get(HashMap.java:313)
org.eclipse.jdt.internal.core.JavaModelManager.getPerProject Info(JavaModelManager.java:910)
org.eclipse.jdt.internal.core.JavaModelManager.getPerProject InfoCheckExistence(JavaModelManager.java:925)
org.eclipse.jdt.internal.core.JavaProject.getPerProjectInfo( JavaProject.java:1651)
org.eclipse.jdt.internal.core.JavaProject.getRawClasspath(Ja vaProject.java:1696)
org.eclipse.jdt.internal.core.JavaProject.getRawClasspath(Ja vaProject.java:1682)
org.jboss.ide.eclipse.xdoclet.run.util.ProjectUtil.populateC lassPath(ProjectUtil.java:50)
org.jboss.ide.eclipse.xdoclet.run.util.ProjectUtil.populateC lassPath(ProjectUtil.java:95)
.... repeated many times ....
If the projects A and B are removed from the EJB's buld path, XDoclet
works as expected (but I really need both for compile). Does anyone have
an idea of how to resolve this?
Ideally, I would like to instruct XDoclet to look at only one Session bean
file, where XDoclet tags are, and ignore everything else, to avoid the
circular action, and even tried the fileset option to exclude all files
except the Session bean, but it did not work.
Eclipse version is 3.0.2, XDoclet 1.2.1, Windows XP Pro.
Any suggestions will be highly appreciated.
Re: XDoclet dies on stack overflow [message #50154 is a reply to message #50062] |
Sun, 10 April 2005 01:11  |
I would inquire from the implementers of
if this is a known bug
HTH
Darins
"Alex Molochnikov" <alex@gestalt.com> wrote in message
news:659102cf21ef28a5d9285fdc0b1e26b5$1@www.eclipse.org...
>I have an EJB project that depends on a number of other projects containing
>variuous classes. Experimentally I found, that when these other projects
>have mutual dependencies, such that project B must be placed into project
>A's build path, and project A must be listed in the build path of B, any
>attempt to create the XDoclet configuration for the EJB project, or to run
>XDoclet, results in the java.lang.StackOverflowError (see the error log
>below):
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.07700 seconds
