Home » Language IDEs » AspectJ » where is aspectjtools.jar?
where is aspectjtools.jar? [message #50007] |
Tue, 15 March 2005 21:42  |
Hi all -
I'm trying to use the Aspect/J ant task "iajc" from Eclipse. I'm using
Eclipse 3.0.1, and AJDT 1.2.0.20041214165937.
Trouble is, I don't see aspectjtools.jar in any of the plugins, and that's
where the AJ Ant tasks are supposed to be, right?
I found AjcTask in ajde.jar in AJDE 1.5 - I didn't even realize that this
was installed in my plugins - but when I try to use it, the task eventually
fails with the following message:
BUILD FAILED: <omitted>\build.xml:54: fail due to NoClassDefFoundError
"org/eclipse/core/runtime/OperationCanceledException""unexpected exception"
(1 exceptions)
SO: what gives? Why is it the Ant task calling back into Eclipse? Where is
aspectjtools.jar? Where should I get the Ant task from?
Larry Edelstein
San Francisco, CA
Here's a complete stack trace of the error:
Buildfile: C:\Documents and Settings\Larry Edelstein\My
Documents\EclipseWorkspace\Server-WhatIsIt\build.xml
init:
dirs:
compile-client:
client:
[iajc] unexpected exception
[iajc] Exception thrown from AspectJ DEVELOPMENT
[iajc] This might be logged as a bug already -- find current bugs at
[iajc]
http://bugs.eclipse.org/bugs/buglist.cgi?product=AspectJ& ;component=Compiler
[iajc] Bugs for exceptions thrown have titles File:line from the top stack,
[iajc] e.g., "SomeFile.java:243"
[iajc] If you don't find the exception below in a bug, please add a new bug
[iajc] at http://bugs.eclipse.org/bugs/enter_bug.cgi?product=AspectJ
[iajc] To make the bug a priority, please include a test program
[iajc] that can reproduce this exception.
[iajc] org/eclipse/core/runtime/OperationCanceledException
[iajc] java.lang.NoClassDefFoundError:
[iajc] at org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :44)
[iajc] at org.aspectj.tools.ajc.Main.run(Main.java:291)
[iajc] at org.aspectj.tools.ajc.Main.runMain(Main.java:227)
[iajc] at
org.aspectj.tools.ant.taskdefs.AjcTask.executeInSameVM(AjcTa sk.java:1162)
[iajc] at org.aspectj.tools.ant.taskdefs.AjcTask.execute(AjcTask.java: 959)
[iajc] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
[iajc] at org.apache.tools.ant.Task.perform(Task.java:364)
[iajc] at org.apache.tools.ant.Target.execute(Target.java:341)
[iajc] at org.apache.tools.ant.Target.performTasks(Target.java:369)
[iajc] at org.apache.tools.ant.Project.executeTarget(Project.java:1214 )
[iajc] at org.apache.tools.ant.Project.executeTargets(Project.java:106 2)
[iajc] at
org.eclipse.ant.internal.ui.antsupport.InternalAntRunner.run (InternalAntRunner.java:377)
[iajc] at
org.eclipse.ant.internal.ui.antsupport.InternalAntRunner.mai n(InternalAntRunner.java:135)
(1 exceptions)
Total time: 741 milliseconds
Re: where is aspectjtools.jar? [message #50039 is a reply to message #50007] |
Fri, 18 March 2005 03:59   |
Hi Larry,
I'm currently using AJDT 1.11.2 so I can't be positive about your problem,
but I wonder if you're using the proper ANT task.
It should be included in aspectjtools.jar not ajde.jar, both jars can be
found in org.aspectj.ajdeplugin in 1.11.2. Considering that aspectjrt.jar
has moved to a new plugin (org.aspectj.runtime) in 1.2.0, maybe
aspectjtools.jar has moved too. Have you tried to search your plugins
directory for aspectjtools.jar ?
Besides, looking at your error message I see that your task tries to load an
internal Eclipse class (org/eclipse/core/runtime/OperationCanceledException)
so maybe it's intended to run in Eclipse JVM and not outside. In Eclipse 3
there is a JVM option in ANT launch configuration where you specify if your
ANT build runs in Eclipse JVM or in a separate JVM (which is the default
option), so you can try to change this setting : "External tools...", "JRE"
tab, "Runtime JRE" group, "Run in the same JRE as the workspace" option.
Nevertheless, I still think you're not using the proper ANT task, it should
be able to run outside Eclipse.
"Larry Edelstein" <ribs@acm.org> wrote in message
news:d186tb$r4b$1@www.eclipse.org...
> Hi all -
eventually
exception"
> (1 exceptions)
is
> Larry Edelstein
> San Francisco, CA
> init:
> dirs:
> compile-client:
> client:
> [iajc]
stack,
bug
> [iajc] at
> [iajc] at
> [iajc] at
er.java:377)
> [iajc] at
ner.java:135)
exception"
> (1 exceptions)
Re: where is aspectjtools.jar? [message #50136 is a reply to message #50039] |
Tue, 22 March 2005 11:58  |
Originally posted by: clemas.uk.ibm.com
Until a version or two ago, org.aspectj.ajde included aspectjtools.jar
and ajde.jar. There was a great deal of duplication between the two and
to reduce the size of the download we removed aspectjtools.jar -
ajde.jar is simply a subset of the contents of aspectjtools.jar. It is
not surprising to see references to eclipse classes when running the
aspectj compiler (or ant task) as our compiler is based on the JDT
compiler. I think the recommendation to run the ANT build in the same
JVM as eclipse should fix the problem. Or download a proper AspectJ
build and install it - that will give you a full standalone
aspectjtools.jar.
Andy.
Sébastien Alonzo wrote:
> Hi Larry,
>>Hi all -
> eventually
> exception"
>>(1 exceptions)
> is
>>Larry Edelstein
>>San Francisco, CA
>>init:
>>dirs:
>>compile-client:
Re: where is aspectjtools.jar? [message #587508 is a reply to message #50007] |
Hi Larry,
> Hi all -
eventually
exception"
> (1 exceptions)
is
> Larry Edelstein
> San Francisco, CA
> init:
> dirs:
> compile-client:
> client:
> [iajc]
stack,
bug
> [iajc] at
> [iajc] at
> [iajc] at
er.java:377)
> [iajc] at
ner.java:135)
exception"
> (1 exceptions)
Re: where is aspectjtools.jar? [message #587554 is a reply to message #50039] |
aspectjtools.jar.
Andy.
> Hi Larry,
>>Hi all -
> eventually
> exception"
>>(1 exceptions)
> is
>>Larry Edelstein
>>San Francisco, CA
>>init:
>>dirs:
>>compile-client:
Current Time: Fri Jul 18 01:56:42 EDT 2025
Powered by FUDForum. Page generated in 0.10850 seconds
