Home » Language IDEs » C / C++ IDE (CDT) » Debug : Cannot step over frame
Debug : Cannot step over frame [message #49986] Wed, 13 November 2002 18:49 Go to next message
Originally posted by: ira.greenstein.calebtech.com
I am currently using:
Eclipse 2.0.2 (also 2.0.1)
CDT: 1.0.0
Solaris: 5.8
GDB: 5.2.1
I get the following error when i try to step into or over a line while
debugging:
8<---8<---8<---8<---8<---8<---8<---8<---8<---8<---8 <---8<---8<---8<---8<---
!ENTRY org.eclipse.debug.ui 4 5012 Nov 13, 2002 18:09:06.260
!MESSAGE Exceptions occurred attempting to step into the frame
!SUBENTRY 1 org.eclipse.cdt.debug.core 4 5010 Nov 13, 2002 18:09:06.267
!MESSAGE org.eclipse.cdt.debug.core.cdi.CDIException: Timedout
!STACK 0
org.eclipse.cdt.debug.mi.core.cdi.CTarget.setCurrentThread(C Target.java:108)
org.eclipse.cdt.debug.mi.core.cdi.CThread.stepInto(CThread.j ava:160)
org.eclipse.cdt.debug.internal.core.model.CThread.stepInto(C Thread.java:551)
org.eclipse.cdt.debug.internal.core.model.CStackFrame.stepIn to(CStackFrame.java:315)
org.eclipse.debug.internal.ui.actions.StepIntoActionDelegate .stepAction(StepIntoActionDelegate
java:24)
org.eclipse.debug.internal.ui.actions.StepActionDelegate.doA ction(StepActionDelegate.java:18)
org.eclipse.debug.internal.ui.actions.AbstractDebugActionDel egate$1.run(AbstractDebugActionDel
egate.java:97)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.debug.internal.ui.actions.AbstractDebugActionDel egate.run(AbstractDebugActionDeleg
ate.java:92)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:210)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.j
ava:407)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:
361)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:352)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionI
tem.java:47)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:853)
Somtimes i can set another breakpoint further in the code and "continue"
to that point and sometimes it just gives me the same error.
Any clues?
Thanks!
ira
Re: Debug : Cannot step over frame [message #50016 is a reply to message #49986] Thu, 14 November 2002 01:19 Go to previous messageGo to next message
Such message usally appeares when CDT cannot connect to gdb for some
reasons. Does something similar appear when you start CDT Debug session?
And try to use gdb(try to use step command) outside Eclipse.
May be it helps...
Igor S. Zamyatin
Interstron Ltd.
> CDT: 1.0.0
> Solaris: 5.8
> GDB: 5.2.1
> debugging:
> !STACK 0
> at
> at
> at
> at
> at
> java:24)
> at
> at
> egate.java:97)
> at
> at
> ate.java:92)
> at
> at
> ava:407)
> at
> 361)
> at
> at
> tem.java:47)
> Any clues?
> Thanks!
> ira
Re: Debug : Cannot step over frame [message #50190 is a reply to message #50016] Thu, 14 November 2002 08:30 Go to previous message
> May be it helps...
> Igor S. Zamyatin
> Interstron Ltd.
> > CDT: 1.0.0
> > Solaris: 5.8
> > GDB: 5.2.1
> > debugging:
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > java:24)
> > at
> > at
> > egate.java:97)
> > at
> > at
> > ate.java:92)
> > at
> > at
> > ava:407)
> > at
> > 361)
> > at
> > at
> > tem.java:47)
> > Any clues?
> > Thanks!
> > ira
Igor, thanks for the quick reply!
I did try gdb on it's own with no problems. I had some odd behavior this
morning when i restarted eclipse. The debugger performed properly...
once! Then, back to the problem as stated above. As i watched the log in
workspace/.metadata, i could bring up CDT without incident and start the
debugger without incident as well. However, as soon as i tried to step i
saw the exception thrown.
I through the whole thing into truss and found the following:
8257: door_info(7, 0xFFBE9A68) = 0
8257: door_call(7, 0xFFBE9A50) = 0
8257: Incurred fault #6, FLTBOUNDS %pc = 0xFA49A9E0
8257: siginfo: SIGSEGV SEGV_MAPERR addr=0x00000000
8257: Received signal #11, SIGSEGV [caught]
8257: sigprocmask(SIG_SETMASK, 0xFF37F010, 0x00000000) = 0
8257: sigprocmask(SIG_SETMASK, 0xFF38ADE0, 0x00000000) = 0
8257: setcontext(0xFFBEB4E0)
8257: Incurred fault #6, FLTBOUNDS %pc = 0xFA5EFEC0
8257: setcontext(0xFFBEAB00)
8257: read(2, "\0", 1) = 1
8257: Incurred fault #6, FLTBOUNDS %pc = 0xFA5DDF40
8257: poll(0xFA281B58, 0, 10) = 0
Also, i forgot to note that i am using j2re1.4.1_01.
Thanks again!
Previous Topic:Newbie question -character placement in editor
Next Topic:Namespaces in C++
Current Time: Mon Nov 17 16:35:48 EST 2025
Powered by FUDForum. Page generated in 0.04067 seconds
