Home » Eclipse Projects » Nebula » Exceptions from Grid
Exceptions from Grid [message #49902] Wed, 27 February 2008 04:39 Go to next message
Originally posted by: vijaya.rao.in.bosch.com
I used Nebula Grid and GridViewer to create a table.i am getting below
exception
1.SHIFT+"Mouse UP" on Row header is giving SWT exception.
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:3547)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.SWT.error(SWT.java:3452)
at org.eclipse.nebula.widgets.grid.Grid.indexOf(Grid.java:2677)
at org.eclipse.nebula.widgets.grid.Grid.getCells(Grid.java:8403 )
at org.eclipse.nebula.widgets.grid.Grid.onMouseDown(Grid.java:6 140)
at org.eclipse.nebula.widgets.grid.Grid.access$6(Grid.java:6038 )
at org.eclipse.nebula.widgets.grid.Grid$10.mouseDown(Grid.java: 5923)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:178)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
com.bosch.autosartool.bsw.ui.configurator.presentation.Confi guratorEditorAdvisor$Application.run(ConfiguratorEditorAdvis or.java:146)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:533)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:155)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Thanks in Advance.
Raghava Rao
Re: Exceptions from Grid [message #49997 is a reply to message #49902] Wed, 27 February 2008 10:21 Go to previous messageGo to next message
Hi Raghava,
I cannot reproduce this problem. Can you give me more information on
how this occurs.
regards,
-Chris
Raghava wrote:
> Hello,
> below exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in Advance.
> Raghava Rao
Re: Exceptions from Grid [message #50216 is a reply to message #49997] Mon, 03 March 2008 04:33 Go to previous message
Hi chris,
I downloaded the latest nightly build and it seems it was fixed.
Thanks for your reply
Raghava
Re: Exceptions from Grid [message #588783 is a reply to message #49902] Wed, 27 February 2008 10:21 Go to previous message
Hi Raghava,
how this occurs.
regards,
-Chris
Raghava wrote:
> Hello,
> below exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in Advance.
> Raghava Rao
Re: Exceptions from Grid [message #588866 is a reply to message #49997] Mon, 03 March 2008 04:33 Go to previous message
Hi chris,
Raghava
Previous Topic:NumberFormatter - Handle null value and empty input
Next Topic:ToolTip widget is not getting disposed properly on Grid Table
Current Time: Tue Nov 18 12:40:53 EST 2025
Powered by FUDForum. Page generated in 0.03493 seconds
