Home » Archived » M2M (model-to-model transformation) » [ATL] How to create a model handler for UML2 in Eclipse 3.1
[ATL] How to create a model handler for UML2 in Eclipse 3.1 [message #49866] Wed, 27 June 2007 15:00 Go to next message
Anybody knows how I can create a model handler for UML2 using:
Eclipse 3.1
UML2 1.1.1
I have tried to checkout the "uml24atl" driver from
the Eclipse CVS but it needs to have installed the org.eclipse.uml2.uml.jar
plugin and I think that it is not available in the uml2 1.1.1 version.
I am a bit lost, I would be very grateful if anybody could help me.
Bea
Re: [ATL] How to create a model handler for UML2 in Eclipse 3.1 [message #50605 is a reply to message #49866] Wed, 04 July 2007 04:39 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Bea a écrit :
> Hello,
Hello Bea,
> Eclipse 3.1
> UML2 1.1.1
We have committed an updated version of the "uml24atl" driver by the end
of last Friday afternoon. In this latest version, we have deleted the
explicit dependence to the org.eclipse.uml2.uml plugin.
It works well with the current versions of Eclipse & UML2 and we are
interested in knowing if it may also solve your problem.
Have you checked out this latest version and tested it with your version
s of Eclipse & UML2?
> Bea
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] How to create a model handler for UML2 in Eclipse 3.1 [message #50738 is a reply to message #50605] Wed, 04 July 2007 08:17 Go to previous messageGo to next message
Hello Hugo,
sorry but I have not written because the last friday I tried with the
updated version and I got another error. The problem I have with the Eclipse
3.1 is related to the org.eclipse.m2m.atl.adt.editor plugin (Now I don't
have any problem with the uml24atl plugin, thank you!!!!). When I check out
this plugin, I get another error with the
org.eclipse.core.runtime.ListenerList plugin because the class
AtlOutlinePage doesn't find it.
Now I am redifining my ATL transformations using UML2 2.0.1 and Eclipse 3.2,
in order not to have those errors :).
Do you know why I have that problem with the org.eclipse.m2m.atl.adt.editor
plugin?
Thank you very much Hugo for your help.
Bea
"Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> escribi
Re: [ATL] How to create a model handler for UML2 in Eclipse 3.1 [message #53182 is a reply to message #50738] Wed, 18 July 2007 11:34 Go to previous messageGo to next message
Hello, I am trying to run an ATL transformation from an Ant script. I am
using:
- Eclipse 3.3
- EMF 2.3
- UML2 2.1
I have also installed ATL and AM3 from CVS. The ATL transformation applies a
profile to a target class diagram, so I need the UML2 model handler. I have
the following problems:
1- When I try to run the atl transformation using an ATL project, I don't
have any problem if I use the EMF model handler. But, if I use the UML2
model handler, I get a window telling me that an internal error ocurried
during launching, and the stereotypes are not applied to the target model.
2- When I try to run the atl transformation using an ant script:
- if I load the models using the UML2 model handler I get the error:
loadMetaModels:
[am3.loadModel] Loading of model UML2
transfo:
[am3.loadModel] Loading of model PRO
[am3.loadModel] Loading of model IN
[am3.atl] Executing ATL transformation
/Plugin/src/plugin/popup/actions/ATLFiles/Primera/Statechart ToClass.asm
[am3.atl] java.lang.NullPointerException
- if I load the models without specifying the model handler (EMF), I get the
error :
loadMetaModels:
transfo:
[am3.atl] ****** BEGIN Stack Trace
[am3.atl] message: ERROR: OclUndefined has no property
Does anybody know where is my problem?
Bea
"Bea" <beaperez@unizar.es> escribi
Re: [ATL] How to create a model handler for UML2 in Eclipse 3.1 [message #53208 is a reply to message #53182] Wed, 18 July 2007 11:45 Go to previous message
In the first Eclipse launch (with the ANT script and the UML2 model handler)
I get the error:
INFO: Loading of model UML2
INFO: Loading of model PRO
INFO: Loading of model IN
INFO: Executing ATL transformation
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
java.lang.reflect.InvocationTargetException
Previous Topic:[ATL] Charging models dynamically in an ATL transformation
Next Topic:Help with TaggedValues
Current Time: Thu Nov 06 01:28:04 EST 2025
Powered by FUDForum. Page generated in 0.05186 seconds
