Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Cannot find operation xyz() for the type (abc)
Cannot find operation xyz() for the type (abc) [message #49856] Mon, 11 September 2006 12:16 Go to next message
Originally posted by: nospam.myemail.fr
Hi all,
I have an enumeration type called Direction that can take "in", "out" or "in
out" as its string literals. I also have an operation as follows in the
enumeration class:
public boolean incoming() {
return this == IN_LITERAL || this == INOUT_LITERAL;
But when I write an OCL constraint such as:
"...port->exists(direction.incoming())" it gives me the following error
during execution
"(Cannot find operation (incoming()) for the type (PortDirection))"
I am at my wit's end and would any help would be greatly appreciated.
Irfan Hamid.
Re: Cannot find operation xyz() for the type (abc) [message #49916 is a reply to message #49856] Tue, 12 September 2006 11:34 Go to previous messageGo to next message
Irfan,
Christian understands what's possible better than me, but I believe the
implementation can only call methods that are modeled as EOperations (on
EClasses) and since you can't define an EOperation for an EEnum, I don't
think you can call this method. Probably your best bet is simply to
test for these two things..
Irfan Hamid wrote:
> Hi all,
> enumeration class:
> during execution
> Irfan Hamid.
Re: Cannot find operation xyz() for the type (abc) [message #49942 is a reply to message #49916] Wed, 13 September 2006 05:23 Go to previous messageGo to next message
Originally posted by: nospam.mymail.fr
Ed,
Ok. Will try that. But in fact what I needed that for was to test the
value of an EEnum. I'm working with two meta-models, one is my own and
generated with EMF2.2. The other is a 3rd-party meta-model that I cannot
change, generated with (I suspect) an older version of EMF. My model is
flat, the 3rd-party model is organized into packages.
For EEnum instances of my own model, I can test the values as
"protocol=TASKPROTOCOL::PERIODIC". This is not possible for EEnum
instances of the 3rd-party model, if I test as
"port.direction=interface::PORTDIRECTION::IN" it will give me an error
saying
java.lang.IllegalArgumentException:
org.eclipse.emf.ocl.parser.SemanticException: ERROR in
(enumerationOrClassLiteralExpCS): (Unknown enumeration literal (IN))
A tell-tale difference between the code generated from my model and that
of the 3rd-party model is that my model's EEnum constructors have the
signature
constructor_name(int value, String name, String literal)
whereas the 3rd-party model's EEnum constructors' signature is
constructor_name(int value, String name)
Irfan Hamid.
Ed Merks wrote:
> Irfan,
> Irfan Hamid wrote:
>> Hi all,
>> or "in out" as its string literals. I also have an operation as
>> follows in the enumeration class:
>> error during execution
>> Regards,
>> Irfan Hamid.
Re: Cannot find operation xyz() for the type (abc) [message #49962 is a reply to message #49942] Wed, 13 September 2006 13:18 Go to previous messageGo to next message
Hi, Irfan,
As Ed indicated, since EEnums cannot define operations, you cannot define
any that would be accessible to OCL. However, that seems beside the point,
now.
Is the name of the PORTDIRECTION enumeration literal "in" (lower case), by
any chance? The names in OCL are case-sensitive, as they are in EMF. The
error message that you got indicates that OCL found the enumeration type
because it says the literal could not be found, rather than
"Unknown type ([interface, PORTDIRECTION, IN])".
HTH,
Christian
Irfan Hamid wrote:
> Ed,
> saying
> signature
> Irfan Hamid.
<snip>
Re: Cannot find operation xyz() for the type (abc) [message #50019 is a reply to message #49962] Wed, 13 September 2006 13:42 Go to previous message
Hi Christian,
I thought of the same thing, here's how the class defines the literal
public static final PORTDIRECTION IN_LITERAL = new PORTDIRECTION(IN, "in");
So I tried also the other value, which is defined as
public static final PORTDIRECTION OUT_LITERAL = new PORTDIRECTION(OUT,
"out");
But still the same error message:
(Unknown enumeration literal (OUT))
Irfan.
PS: Could it have anything to do with the fact that the constructor used
does not accept a String literal as follows:
public static final TASKPROTOCOL PERIODIC_LITERAL = new
TASKPROTOCOL(PERIODIC, "PERIODIC", "PERIODIC");???
Christian W. Damus wrote:
> Hi, Irfan,
> now.
> HTH,
> Christian
> Irfan Hamid wrote:
>>Ed,
>>saying
>>signature
>>Regards,
>>Irfan Hamid.
> <snip>
Re: Cannot find operation xyz() for the type (abc) [message #590814 is a reply to message #49856] Tue, 12 September 2006 11:34 Go to previous message
Irfan,
Irfan Hamid wrote:
> Hi all,
> enumeration class:
> during execution
> Irfan Hamid.
Re: Cannot find operation xyz() for the type (abc) [message #590844 is a reply to message #49916] Wed, 13 September 2006 05:23 Go to previous message
Ed,
saying
signature
Irfan Hamid.
Ed Merks wrote:
> Irfan,
> Irfan Hamid wrote:
>> Hi all,
>> Regards,
>> Irfan Hamid.
Re: Cannot find operation xyz() for the type (abc) [message #590858 is a reply to message #49942] Wed, 13 September 2006 13:18 Go to previous message
Hi, Irfan,
now.
HTH,
Christian
Irfan Hamid wrote:
> Ed,
> saying
> signature
> Irfan Hamid.
<snip>
Re: Cannot find operation xyz() for the type (abc) [message #590897 is a reply to message #49962] Wed, 13 September 2006 13:42 Go to previous message
Hi Christian,
"out");
Irfan.
> Hi, Irfan,
> now.
> HTH,
> Christian
> Irfan Hamid wrote:
>>Ed,
>>saying
>>signature
>>Regards,
>>Irfan Hamid.
> <snip>
Previous Topic:WrongPrimayKeyException and MissingColoumnExceptions while using elver with jpox
Next Topic:JET2 Documentation
Current Time: Fri Jul 25 22:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.06303 seconds
