| Report Parameters [message #49804] |
Wed, 22 June 2005 15:27  |
In version 1.0, when ever I try to bind report parameters to parameters in a
data set, I get the following error (when I try to preview the results):
Invalid Javascreipt expression: Source: ParamBinding(Currency), line: 0,
Expression: params["Currency"]
Script engine error: ReferenceError: "params" is not defined.
Reason:
A Birt exception occurred.
Note that params["Currency"] is what the 'Expression builder' puts in when I
select the Currency report parameter.
Any ideas?
Thanks!
Rick
| Re: Report Parameters [message #50883 is a reply to message #49804] |
Thu, 23 June 2005 16:10  |
Please file a bugzilla report so a BIRT engineer can take a look. Make sure
that the report design file that's giving your the problem is attached to
the report.
thanks,
Gary Xue
"Rick Spickelmier" <ricks@spickelmier.com> wrote in message
news:d9ce3r$6nr$1@news.eclipse.org...
a
> Reason:
I
> Any ideas?
> Thanks!
> Rick
FUDForum. Page generated in 0.29110 seconds
