Home » Language IDEs » PHP Development Tools (PDT) » different line numbers in xdebug view
different line numbers in xdebug view [message #49768] Sat, 08 September 2007 11:27 Go to next message
Hello Newsgroup,
I am curious if I am the only one with the following debugging
problem:
Quite often the line highlighted in debug view is not the
line the script is currenly executing.
I am using the most recent PDT build and xdebug2.0.0 RC4
Has anyone seen this behaviour? Should I open a bug report?
Greetings,
Oliver
Re: different line numbers in xdebug view [message #49798 is a reply to message #49768] Sun, 09 September 2007 06:26 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Have you tried the official release of 2.0 of xdebug ? There
may be some bug fixes that resolve this.
If not, can you provide an example script demonstrating the problem ?
Also which level of php are you using ?
Cheers
Dave Kelsey
Oliver Trosien wrote:
> Hello Newsgroup,
> problem:
> Greetings,
> Oliver
Re: different line numbers in xdebug view [message #50407 is a reply to message #49798] Tue, 11 September 2007 15:36 Go to previous message
I had the same problem, although it didn't happen every time, even in the
same file.
I was using the latest PDT, xdebug 2.0.0 RC4, and PHP 5.2.3 on a remote
server. I'm going to upgrade to xdebug 2.0.0 final and see if that helps.
Jacob
"Dave" <dkel50@hotnospmail.com> wrote in message
news:fc0hp6$tn7$1@build.eclipse.org...
Previous Topic:Problems with indent level using multiline comments
Next Topic:PDT 1.0 Webinar
Current Time: Tue Jul 08 23:38:36 EDT 2025
Powered by FUDForum. Page generated in 0.31267 seconds
