Home » Newcomers » Newcomers » Importing Preferences
Importing Preferences [message #49748] Sat, 09 April 2005 06:08 Go to next message
Originally posted by: bobostro.comcast.net
Every time you create a new project folder and use it as a workspace, you
need to go in to Window/Preferences and reset all of the editor
preferences (ie. code formatter, etc.). I notice there is an import
button you can use in the lower left corner of the preferences window
where you can select a file to import preferences.
What file do you need to import to bring the codeformatter settings and
template settings into the new workspace?
Re: Importing Preferences [message #49780 is a reply to message #49748] Sat, 09 April 2005 07:50 Go to previous messageGo to next message
Never mind. After drilling through the .metadata file for each workspace
folder I have, I found the needed files to copy. If anybody is
interested, they are:
..\.metadata\.plugins\org.eclipse.core.runtime\.settings\org .eclipse.jdt.ui.prefs
and
..\.metadata\.plugins\org.eclipse.core.runtime\.settings\org .eclipse.jdt.core.prefs
Re: Importing Preferences [message #50720 is a reply to message #49748] Mon, 11 April 2005 13:41 Go to previous message
Originally posted by: dj_houghton.nospam.ca.ibm.com
When using a new workspace, I do a File->Import->Preferences on the file
that I exported via File->Export->Preferences. (3.1 stream builds)
In Eclipse 3.0 and previous there are import/export buttons directly on
the preference dialog.
> you need to go in to Window/Preferences and reset all of the editor
Previous Topic:java.lang.UnsatisfiedLinkError
Next Topic:Get Eclipse to use javadoc doclets.
Current Time: Fri Jul 25 14:04:31 EDT 2025
Powered by FUDForum. Page generated in 0.33301 seconds
