Home » Archived » XML Schema Definition (XSD) » How to get declaration in the order defined in XML Schema file
How to get declaration in the order defined in XML Schema file [message #49735] Mon, 02 August 2004 14:09 Go to next message
I noticed that XSDSchema.getAttributeDeclarations(),
getAttributeGroupDefinitions(), and getElementDeclarations() all return
the declarations in an alphabetic order, rather than the original order
defined in the XSD file. Is there a way to get those declarations
according to the order provided in the XSD file?
Thanks.
Joshua
Re: How to get declaration in the order defined in XML Schema file [message #49765 is a reply to message #49735] Tue, 03 August 2004 06:52 Go to previous message
Joshua,
XSDSchema.getContents will return the physical declarations contained by
a given schema in source order.
Joshua Hui wrote:
> return the declarations in an alphabetic order, rather than the
> original order defined in the XSD file. Is there a way to get those
> declarations according to the order provided in the XSD file?
> Thanks.
> Joshua
Re: How to get declaration in the order defined in XML Schema file [message #589987 is a reply to message #49735] Tue, 03 August 2004 06:52 Go to previous message
Joshua,
Joshua Hui wrote:
> Thanks.
> Joshua
Previous Topic:How to get declaration in the order defined in XML Schema file
Next Topic:xsd:any - namespace problem
Current Time: Sun Nov 09 02:17:31 EST 2025
Powered by FUDForum. Page generated in 0.03241 seconds
