Home » Modeling » OCL » extents in UML and OCL
extents in UML and OCL [message #49719] Fri, 25 January 2008 08:31 Go to next message
Originally posted by: krzysztof_kaczmarski.o2.pl
Hi All,
Do UML's ReadExtentAction and OCL's allInstances return only instances
of a given classifier or also instances of its specializations?
I cannot find this in the specifications.
Thanks in advance,
Krzysztof
Re: extents in UML and OCL [message #49749 is a reply to message #49719] Fri, 25 January 2008 09:34 Go to previous messageGo to next message
Hi, Krzysztof,
MDT OCL interprets allInstances() literally as returning all objects whose
type conforms to the target classifier. i.e., including specializations
I think this is the only useful interpretation for UML, itself, in which so
many metaclasses are abstract. They would have empty extents under the
other interpretation.
Regarding the ReadExtentAction, you might ask on the UML2 newsgroup ...
perhaps there is already an issue asking for clarification that somebody
knows about.
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> Thanks in advance,
> Krzysztof
Re: extents in UML and OCL [message #49837 is a reply to message #49749] Fri, 25 January 2008 10:59 Go to previous messageGo to next message
Thanks Christian.
I understand that MDT's implementation comes from creative reading of
the specification.
I sent the same mail to the uml2 newsgroup but misspelled the group name:)
Krzysztof
Christian W. Damus wrote:
> Hi, Krzysztof,
> knows about.
> Cheers,
> Christian
>> Hi All,
>> Thanks in advance,
>> Krzysztof
Re: extents in UML and OCL [message #49867 is a reply to message #49837] Fri, 25 January 2008 13:00 Go to previous messageGo to next message
Hi, Krzysztof,
Heh heh ... I don't know about "creative reading." I thought it was an
obvious interpretation!
In any case, this is only MDT OCL's default behaviour. In fact, by default,
the extent of any class is lazily computed (and cached) from the instances
in the current Resource.
However, you can customize this implementation for your application. Simply
provide your own "extent map" to the org.eclipse.ocl.OCL object or
implement a custom EvaluationEnvironment that implements the
createExtentMap() method.
HTH,
Christian
> Thanks Christian.
> the specification.
> Krzysztof
-----8<-----
Re: extents in UML and OCL [message #49895 is a reply to message #49867] Fri, 25 January 2008 14:13 Go to previous messageGo to next message
Hi, Christian
It would be obvious interpretation if extent was somewhere explicitly
defined. My feeling is that an 'object model' (as a set of commonly
understood notions) must be somehow defined in specifications like
this. Otherwise questions like: what is class, what is object, what is
reference, what is value, what is extent, what is type and many other
will appear sooner or later.
Krzysztof
> Hi, Krzysztof,
> HTH,
> Christian
>> Thanks Christian.
>> the specification.
>> Regards,
>> Krzysztof
> -----8<-----
Re: extents in UML and OCL [message #49925 is a reply to message #49895] Fri, 25 January 2008 14:53 Go to previous message
Hi, Krzysztof,
I think it is explicitly defined.
From the Semantics of Classifier metaclass in the 2.1 Superstructure:
"A Classifier may participate in generalization relationships
with other Classifiers. An instance of a specific Classifier
is also an (indirect) instance of each of the general
Classifiers."
And from the Semantics of ReadExtentAction:
"The extent of a classifier is the set of all instances of a
classifier that exist at any one time."
From these two statements, as long as the term "instance" means the same in
both, I conclude that the extent of a classifier includes the extents of
its specializations.
HTH,
Christian
> Hi, Christian
> Cheers,
> Krzysztof
>> Hi, Krzysztof,
>> default, the extent of any class is lazily computed (and cached) from the
>> instances in the current Resource.
>> Simply provide your own "extent map" to the org.eclipse.ocl.OCL object or
>> HTH,
>> Christian
>>> Thanks Christian.
>>> the specification.
>>> Regards,
>>> Krzysztof
>> -----8<-----
Previous Topic:How to access operation return values in OCL postconditions ?
Next Topic:[OCL Tools] Downloads
Current Time: Sat Jul 12 21:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.24937 seconds
