Home » Language IDEs » AspectJ » newbie question
newbie question [message #49688] Wed, 09 March 2005 06:02 Go to next message
Originally posted by: hmcbride.curamsoftware.com
Am quite new to aop , currently investigating the use of eclipse and
aspectj for detecting illegal method calls ( i.e policy enforcement).
There is a code pattern
that we are looking to detect , a double for loop that contains certain
set methods i.e.
for(int i = 0; i< 10; i++)
for(int j = 0; j< 10; j++)
classInstanceA.setObscureVar(blah);
classInstanceB.setOtherObscureVar(blahblah);
this to prevent certain variable from being overwritten.
Is there any way I can detect this type of construct using aop.
Any pointers /suggestions welcome
thanks in advance
H
Re: newbie question [message #49718 is a reply to message #49688] Wed, 09 March 2005 07:35 Go to previous messageGo to next message
Originally posted by: Rafal.Krzewski.caltha.pl
Hugh McBride wrote:
> There is a code pattern that we are looking to detect , a double for
> loop that contains certain set methods i.e.
It is a valid use case for AOP, but AFAICT it is impossible to do this
using AspectJ.
The problem is the implemented join point model. In AOP there are many
kinds of join points, including for loop body execution. Actual AOP
implementations, like AspectJ support only a subset of the possible join
points that can be matched by pointcuts in your aspects. The joinpoints
that are left out are those that cannot be reliably described: If you
have several loops in a single method, how do you describe in the
pointcut which loop do you mean?
At this point AspectJ does not provide a pointcut for picking out code
blocks (like loop or conditional bodies), so you won't be able to detect
that anti-pattern with AspectJ.
regards,
Rafal
Re: newbie question [message #49746 is a reply to message #49718] Wed, 09 March 2005 10:49 Go to previous messageGo to next message
> using AspectJ.
> regards,
> Rafal
Thanks Rafal, What does AFAICT stand for ?
Bruno Harbulot seems to be doing some work wrt loop detection and aspects
see his page at
http://www.cs.man.ac.uk/cnc/students/harbulob/
Re: newbie question [message #49806 is a reply to message #49746] Thu, 10 March 2005 12:26 Go to previous message
Originally posted by: adrian.redpointsoft.com
As Far As I Can Tell.
-a.
Re: newbie question [message #587353 is a reply to message #49688] Wed, 09 March 2005 07:35 Go to previous message
using AspectJ.
regards,
Rafal
Re: newbie question [message #587361 is a reply to message #49718] Wed, 09 March 2005 10:49 Go to previous message
> using AspectJ.
> regards,
> Rafal
see his page at
Re: newbie question [message #587398 is a reply to message #49746] Thu, 10 March 2005 12:26 Go to previous message
-a.
Previous Topic:Where to begin? java.lang.NoSuchFieldError: ajc$cflowCounter$0
Next Topic:Where to begin? java.lang.NoSuchFieldError: ajc$cflowCounter$0
Current Time: Sat Oct 25 03:27:09 EDT 2025
Powered by FUDForum. Page generated in 0.04749 seconds
