Home » Newcomers » Newcomers » java.lang.UnsatisfiedLinkError
java.lang.UnsatisfiedLinkError [message #49598] Fri, 08 April 2005 19:00 Go to next message
I am new to eclipse, I just installed the latest eclipseSDK_3.1M6 & tptp
builds. and wrote my first SWT app by just copying main() from the eclipse
tutorial which is somewhat outdated. Somehow the dll file is not in the
plugins\, but somewhere in the configurations\, so I copied it to the
following location.
-Djava.library.path=C:\eclipse_org_SDK3.1M6\eclipse\plugins\ org.eclipse.swt.win32_3.1.0\os\win32\x86
Still, it still can not find swt-win32-3128.dll. Can somebody help me with
this?
Thanks!
-yu
java.lang.UnsatisfiedLinkError: no swt-win32-3128 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
at HelloWorld.main(HelloWorld.java:20)
Exception in thread "main"
Display display = new Display();
Shell shell = new Shell(display);
Label label = new Label(shell, SWT.CENTER);
label.setText("Hello_world");
label.setBounds(shell.getClientArea());
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: java.lang.UnsatisfiedLinkError [message #49625 is a reply to message #49598] Fri, 08 April 2005 19:26 Go to previous messageGo to next message
Yu Chen wrote:
> Hello,
> following location.
> this?
> Thanks!
> -yu
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
I had a similar problem with 3.1M6 where it couldn't find the swt dll to
run my SWT application. The dll is in the swt jar. I copied the dll
out of the jar into a directory on the library path so it could be found
and then the application would run.
Re: java.lang.UnsatisfiedLinkError [message #49656 is a reply to message #49625] Fri, 08 April 2005 19:46 Go to previous messageGo to next message
I saw people had similar problem, and I also unjar the following jar file
from the plugins\. But I still got the same error, I can see the 3128.dll
file is in the java.library.path, but it just can not be found from the
simple swt program, what's wrong, any ideas??
C:\eclipse_org_SDK3.1M6\eclipse\plugins\org.eclipse.swt.win3 2_3.1.0.jar
The above jar also included in the CLASSPATH.
"Steve Blass" <swb@aurora.phys.utk.edu> wrote in message
news:d374ab$c16$1@news.eclipse.org...
> Yu Chen wrote:
>> Hello,
>> eclipse tutorial which is somewhat outdated. Somehow the dll file is not
>> in the plugins\, but somewhere in the configurations\, so I copied it to
>> the following location.
>> with this?
>> Thanks!
>> -yu
>> shell.open();
>> display.sleep();
>> display.dispose();
> run my SWT application. The dll is in the swt jar. I copied the dll out
> of the jar into a directory on the library path so it could be found and
Re: java.lang.UnsatisfiedLinkError [message #49930 is a reply to message #49656] Sat, 09 April 2005 18:05 Go to previous messageGo to next message
"Yu Chen" <yuchen@bea.com> wrote in message
news:d375ds$d8k$1@news.eclipse.org...
Under M6, you need to extract the three DLLs from the new
org.eclipse.swt.win32_3.1.0.jar file and copy them to your windows/system32
directory (or somewhere else on yoru path).
You should then be able to use "Run As > Java Application" to run them.
Don't use "Run As > SWT Application" as that is broken in M6.
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
http://www.instantiations.com
http://www.swt-designer.com
Author: "Eclipse: Building Commercial Quality Plug-ins"
http://www.awprofessional.com/title/0321228472
Re: java.lang.UnsatisfiedLinkError [message #50692 is a reply to message #49930] Mon, 11 April 2005 12:00 Go to previous message
Thanks!! It works now, I copied the dlls to the system32 dir. -yu
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:d39jsl$1oj$1@news.eclipse.org...
> windows/system32 directory (or somewhere else on yoru path).
> -Eric Clayberg
Previous Topic:Loading Images in plug-in
Next Topic:Importing Preferences
Current Time: Wed Nov 05 07:48:01 EST 2025
Powered by FUDForum. Page generated in 0.33217 seconds
