| Link with .NET component [message #49517] |
Tue, 27 May 2003 09:20  |
Originally posted by: ebriere.codagen.com
Hi all,
I built a testing component using .NET (C#). I try to invoke it from SWT.
Everthing works fine except for event handling. It seems that my assembly
recognize that a listener is connected to it but I get an exception from the
..NET side when it tries to return back the control to my plug-in (I think).
Someone else has experienced the same problem?
Thanks!
| Re: Link with .NET component [message #50571 is a reply to message #49517] |
Tue, 27 May 2003 16:16  |
Finally got the twist. Hope this partial code helps someone...
Partial Plug-In Code in Java
webControlSite = new OleControlSite(frame, SWT.NONE,
"MyNetControl.UserControl1");
OleAutomation automation = new OleAutomation(webControlSite );
webControlSite.doVerb(OLE.OLEIVERB_UIACTIVATE );
int dispIdMember2 = 101;
webControlSite.addEventListener ( dispIdMember2, new OleListener() {
public void handleEvent(OleEvent event) {
// Do something here....
return;
Partial C# code...
using System.Runtime.InteropServices;
namespace MyNetControl
public delegate void ClickEventHandler();
[Guid("47C976E0-C208-4740-AC42-41212D3C34F0"),
InterfaceType(ComInterfaceType.InterfaceIsIDispatch)]
public interface Events
[DispId(101)]
void ClickEvent();
[Guid("9E5E5FB2-219D-4ee7-AB27-E4DBED8E123E"),
ClassInterface(ClassInterfaceType.None),
ComSourceInterfaces(typeof(Events))]
public class UserControl1 : System.Windows.Forms.UserControl
event ClickEventHandler ClickEvent;
private void button1_Click(object sender, System.EventArgs e)
if (ClickEvent != null)
ClickEvent();
else
MessageBox.Show("oups!");
"Eric" <ebriere@codagen.com> wrote in message
news:bavoma$t9n$1@rogue.oti.com...
> Hi all,
the
think).
> Thanks!
FUDForum. Page generated in 0.08574 seconds
