Home » Archived » OHF » modify the CDA encoding
modify the CDA encoding [message #49513] Sun, 14 December 2008 01:58 Go to next message
The default CDA document's encoding is
<?xml version="1.0" encoding="ASCII"?>
I want to set the encoding to UTF-8,How do it?
Thanks!!!!!
Re: modify the CDA encoding [message #49604 is a reply to message #49513] Mon, 15 December 2008 13:37 Go to previous message
Hi Robert,
This is a property in EMF. My best guess is:
xResource.getDefaultSaveOptions().put(XMLResource.OPTION_DEC LARE_XML,
Boolean.TRUE);
xResource.getDefaultSaveOptions().put(XMLResource.OPTION_ENC ODING, "UTF-8");
beyond that, I'm not sure and you'll have to read EMF documentation to
on the XMLResource package.
additionally see:
https://iheprofiles.projects.openhealthtools.org/
The user forum can be found here:
https://iheprofiles.projects.openhealthtools.org/ds/viewForu mSummary.do?dsForumId=212
Unfortunately, due to spam, guest posting is disabled so please become a
member of the project.
regards,
- Sarah
RobertHua wrote:
> The default CDA document's encoding is <?xml version="1.0"
> encoding="ASCII"?>
> Thanks!!!!!
Re: modify the CDA encoding [message #588089 is a reply to message #49513] Mon, 15 December 2008 13:37 Go to previous message
Hi Robert,
Boolean.TRUE);
additionally see:
regards,
- Sarah
> encoding="ASCII"?>
> Thanks!!!!!
Previous Topic:store CDA into database
Next Topic:test 11746 to a local freebxml (OMAR) repository
Current Time: Fri Jul 18 05:19:45 EDT 2025
Powered by FUDForum. Page generated in 0.34202 seconds
